03-29-2017, 12:04 PM | #1 |
'Maro
Drives: 2015 SS 6.2L Auto 2SS Join Date: Sep 2016
Will these fit?
2015 Camaro 2ss. I'm sure it depends on tire size, can I fit these wheels with a tire combo that won't rub? How about flush with fenders? I'm a newb at offset and such. Any input is appreciated thanks!!
2015 SS 2SS Auto 93 SCT Perf, Kooks LTH & HFC MBRP Axleback Muffler Delete "Z/28" Spoiler and Grille OEM ZL1 wheels 285/305/35R20 BFG G-force Pro Comp 2
03-29-2017, 12:13 PM | #2 |
Drives: 2015 camaro 2lt Join Date: Dec 2016
should work bit wide for front then normaly
Cosmetic mods: SS hood with painted vent, SS bumper, acs 1le front lip black, big worm gfx tinted all lights, solar wing v2, Camaro seat belt pads and oracle color shift halos and fog light halos and rear colorshift bow tie, carbon creations carbon fiber stingray z spoiler
Wheels: lexani r-3 bg finish 19x8.5 Performance: cold air inductions intake, mrt v1, jacfab ported intake manifold, intake manifold spacer, overkill tuned on E85. |
03-29-2017, 12:54 PM | #3 |
Drives: 2017 Chevrolet SS 1LE Join Date: Oct 2016
Yes they can, have a shorty stem applied upfront and worst case a 5 mm spacer upfront
03-29-2017, 01:14 PM | #4 | |
Drives: 2012 RS/2SS, 69 ProStreet Camaro Join Date: Oct 2011
03-29-2017, 03:00 PM | #5 |
03-29-2017, 05:06 PM | #6 |
'Maro
Thank you guys, so can you recommend a tire size that works?
These are almost too wide I'm thinking for me, and kinda too much right now budget wise. But I'm trying to barter a bit with the guy so who knows. I really think those would look good Offset is going to look better than this then?
03-29-2017, 05:07 PM | #7 | |
'Maro
03-30-2017, 09:44 AM | #8 |
Drives: 2015 Camaro 1SS L99 Join Date: Apr 2016
Lots of options for tires on 20x10.5 I run 275/40/20 currently and they are fine - but IF youre buying tires I would look at maybe 285-305 and anywhere from 40-30. Ill probably buy 305/35 when its time to buy tires again so as long as the price doesn't kill me. 285/40 would be a good option for you if your on budget probably.
03-30-2017, 09:59 AM | #9 | |
'Maro
03-30-2017, 11:12 AM | #10 |
275/40/20 is the bang for the buck size.
03-30-2017, 11:51 AM | #11 |
Drives: 2020 Orange Crush 1SS/1LE Join Date: Jun 2016
The rear will be almost identical to the ZL1, but the front will be a close call, I am running 285/35/20 up front with 10x35, and it is close to the strut. You can run that set up with a 5mm spacer, and still run the 285's square.
03-30-2017, 12:29 PM | #12 | |
'Maro
Appreciate that, thanks for the response
Appreciate your input
03-31-2017, 01:32 PM | #13 |
your welcome.
