02-08-2017, 09:11 PM | #1 |
Drives: Camaro 2017 1LE Join Date: Feb 2016
Rim scrape damage advice
I guess its inevitable with these large rims, Ive been carefully breaking in the car going on some long highway road trips each day to get to 1500 by my track day next weekend
See below came home and saw this scrape so weird cause I didn't park it anywhere near curbs or anything * I did end up on some weird back roads that seemed to have construction zones What are my options? Is there such thing as touch up for these rims? I have tire and rim protection package ins but im not gonna use it for a mild scrape and not sure how many times i can use it. I imagine at least wait until track season is over . After my initial damage ive been so careful! So this is bothersome but again I realize its likely to get more scrapes on the track so im slowly preparing my self Advice ? |
02-08-2017, 09:58 PM | #2 |
Drives: Challenger SP Shaker/Arcadia Denali Join Date: Jan 2016
Wheel Wizard Wheel Repair -
3695 Longview Dr, Atlanta, GA 30341Phone:(770) 451-6333 Some place like this in your area maybe would be best IMO. |
02-08-2017, 10:15 PM | #3 |
02-09-2017, 07:34 AM | #4 |
Thy want to re coat the whole wheel no matter how big or small ? Is this what I should do ? Or should I wait until after track season ?
02-09-2017, 07:51 AM | #5 |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
If they don't do that you will see the area they repaired...I've had the wheels on my wife's truck fixed twice. First time I didn't have them paint the whole wheel, I could see the area that was worked on. Would someone else? Doubtful...but the next time I had the whole wheel painted and you couldn't tell. Just make sure the guy you use has good reviews, as that is not a cheap wheel.
02-09-2017, 08:45 AM | #6 |
I wonder if it's better to get a new wheel ! For the cost and repair this one as an alternate ?
02-09-2017, 08:47 AM | #7 |
What about the wheel tire ins I bought ? Does that cover this w quality work
02-09-2017, 08:56 AM | #8 |
Drives: 2016 2SS M6 Mosaic Blk Met-SOLD Join Date: Jun 2016
You can make that unnoticeable pretty easily by yourself with a Dremel tool and touch up paint.
Start with the Dremel #952 Cone Shaped Aluminum Oxide Grinding Stone and grind down the burrs. It doesn't have to be completely smooth just rounded the best you can. Switch to the #413 Sanding disc and try to round it down. 1500 grit sandpaper lightly sand 3000 grit sand paper lightly sand Clean with 15% isopropyl alcohol/water solution Paint with rim touch up paint.
Official Detailer of CamaroFest 8 & 9
https://www.autogeekonline.net/forum...st-8-pics.html https://www.camaro6.com/forums/showt...=521655&page=1 https://www.camaro6.com/forums/showt...=547470&page=1 https://www.camaro6.com/forums/showthread.php?t=527474 No one on Earth has detailed more Camaros. http://KirkTheDetailer.com |
02-09-2017, 08:58 AM | #9 | |
Drives: 2017 Camaro SS Convertible 50th Join Date: Nov 2016
02-09-2017, 09:15 AM | #10 |
Retired from Car mfrs....
Drives: 2LT RS/HR-V Join Date: May 2013
I disagree a little bit. I don't think it takes redoing the whole wheel. I've seen jobs come out of a used car department via mobile wheel repair where they didn't do the whole wheel and you can't tell that there was ever a problem. Go back to the dealer, go see the used car manager , and ask them who they use for their mobile repair. Every dealer has one, and maybe it's a service that will even come to your house. Should be 100 bucks . Maybe less
02-09-2017, 09:44 AM | #11 |
Found a place that said re painting whole wheel was overkill ! Gonna. Have them sand and touch up , not sure what tire and wheel coverage actually covers ?
02-09-2017, 10:10 AM | #12 | |
02-09-2017, 10:14 AM | #13 |
Drives: 2001 Onyx Black/Ebony SS. 427/M6 Join Date: Apr 2016
If you have a wheel/tire insurance package you paid for, you should have gotten a contract or pamphlet of some sort that states what is coverage by you insurance. Some places will fix scratches such as yours, Ive heard of others that will only replace the wheel. Some will only fix bends and again, others will only replace them. Look through the info you got with your car, i.e. owners manuals, warranty manuals etc and there should be some info there. Otherwise call the dealer you purchased it from and they can look up your contract.
02-09-2017, 10:31 AM | #14 |
Drives: 2013 C6Z06 Join Date: Nov 2016
Sell all of your wheels and tires to me, they are junk
