Roto-Fab
Old 02-03-2017, 06:17 PM   #1
Jpax
Drives: ZL1
ZL1 or 1LE
Evening all,
I have been considering getting back into a 5th gen Camaro. At first I was set on the 2014/15 1LE. but I can pick up a 14/15 ZL1 for 9k more and it leads me to question if I should go the ZL1 way...
My question is, what is a better daily drivers car? if I go the 1LE route, and decide to add power. I would almost the same $$ to get to the ZL1 power range if just spent the extra now and went for the ZL1.
anyone owned both? or have any input would be greatly appreciated
Jpax is offline   Reply With Quote
Old 02-03-2017, 06:34 PM   #2
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
I haven't driven either but I vote ZL1 for the magnetic ride with 5 different settings.
2011 1SS/RS LS3 CGM
Old 02-03-2017, 07:43 PM   #3
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
The ZL1 is far superior in every way.
Old 02-03-2017, 07:44 PM   #4
Gunmetal Speedster
Gunmetal Speedster's Avatar
Drives: Savitar; The 500rwhp N/A Monster!
Modding the ZL1 would put down mass power as well, as if it doesn't have enough already haha.
*SOLD*504HP/433TQ | Night Fury cammed • Cold Air Inductions intake • Bo White ported TB • Speed Engineering 1 7/8 longtubes • NPP catback • QTP low profile cutouts • Powerbond 25% UDP • 3.73 gears • JRE scoop • ZL1 grille • R1 Concepts drilled/slotted rotors • built/tuned by Weapon X Motorsports
Gunmetal Speedster is offline   Reply With Quote
Old 02-03-2017, 07:44 PM   #5
Jpax
Drives: ZL1
Magnetic ride is definitely a plus over the less compliant 1LE more track focused suspension.
Old 02-03-2017, 07:53 PM   #6
sdynak
Drives: 2010 1SS
If you are sure the mods you would put in the 1LE over time would narrow the cost then that kind of helps your decision if you can swing it now.. I would say it really comes down to condition & miles with respect to price for each also. The ZL1 is obliviously the superior choice all around all things being equal for condition and if budget allows. In the end it's your choice. Do what feels right to you. Not everyone wants to spend the extra $ for something they don't need so sleep on it and go for it.
2010 1SS LS3, Black, 235/250, .621/.615, 114 + 4, Kooks Stepped Headers, 3.91's, Bo White PTB, Flowmaster Mufflers, Cold Air Industries CAI, Apex Scoop & Windshield Washer Relocate, SLP Wheels, Skip Shift Eliminate, Barton Flat Stick, OEM HID/Halos, Dyno Tuned by ECS
sdynak is offline   Reply With Quote
Old 02-03-2017, 08:06 PM   #7
JCunningham
Drives: 2017 2SS M6
If I had only had the money I have put into my car when I bought the camaro I would have a better car then I have now just buying a stock ZL1.
Old 02-03-2017, 08:35 PM   #8
Jpax
Drives: ZL1
currently the two cars are very similar, the 1LE is a 14 with 14,000k and the ZL1 is a 14 with 11,000k. so both are very similar, the 1LE is white 2ss fully loaded. the ZL1 well its the deep red and well equipped. I figure down the road I will most likely do the typical I-H-C mods etc... so price wise it tough to decide. second and a tough one for me. its winter here and I cant really get one on the road, so I am really deciding blind here!
the plus to buy now, is its the off market now so I will get a better deal...
Old 02-03-2017, 08:48 PM   #9
JCunningham
Drives: 2017 2SS M6
Don't drive on the stock tires and look hard for cracking. Those tires are not supposed to see Temps below 40 degrees. I checked out a 13 z06 this spring. They had put new tires on it in the fall then it sat out side all winter. All 4 were cracked.
Old 02-03-2017, 08:51 PM   #10
sdynak
Drives: 2010 1SS
I'd push on the ZL1 hard first.. Make them a final offer and try to close the gap.. Red ZL1 ugg! .. not a question to me.. It would be in my garage if I were you already LOL.. Not much to really do but drive it and smile.
Old 02-03-2017, 09:19 PM   #11
Jpax
Drives: ZL1
ya the red is sweet, and I have only seen it indoors so outside must be amazing...
Old 02-03-2017, 09:25 PM   #12
sdynak
Drives: 2010 1SS
Man.. dude jump on that beast before someone else does!!
Old 02-03-2017, 09:44 PM   #13
DeSH
DeSH's Avatar
Drives: 2013 ZL1 A6 #4801
Get the ZL1. If you're questioning it now, you surely will if you get the 1LE. I'm biased BTW.
DeSH is offline   Reply With Quote
Old 02-03-2017, 10:05 PM   #14
Jpax
Drives: ZL1
I am leaning to z... thanks all for chiming in!
