01-23-2017, 04:25 PM | #1 |
Drives: 2010 Camaro SS Join Date: Jan 2015
Cam & Fuel system Done!! WOW
I wanted to try a fuel system configuration and see how far I can go with it. I am running Fore dual 450’s in a NON return setup..So far it is working great! The Vaporworx unit can be setup in two configurations, first is constant pressure like our stock FPCM (however the Vaporworx unit can deliver up to 60A) the second configuration is boost reference. This is how I setup my system, in a boost reference setup the system mimics a return system with a 1:1 rise in FP. I set my base pressure to 58 at idle I’m seeing 52 psi FP under boost I see 70psi rock solid.
The system consists of the following: Fore dual pump hat w/ 450’s 2 psi Hobbs switch on the second pump Vaporworx controller 1000cc injectors -6 feed line to the stock rail I have had a turbo on my car for a couple of years now and the car made good power on the 100% stock engine. On E85 the car made 656rwhp at 12psi. Not bad right, well I decided it was time for the LS3 conversion and a nice turbo cam. I settled on the Tick Performance stage 2 turbo cam with the new fuel system and cam at 13 psi the car made 740RWHP through a 6L80 trans! Needless to say very happy with the results and my IDC was at 70% |
01-23-2017, 06:27 PM | #2 |
Drives: 2010 SS/RS LS3 M6 Join Date: Apr 2011
That's sweet, Vaporworx figured out a non return pump controller for high hp apps., I know he has been working on it for sometime, opens things up now for those who don't want a return setup.
01-23-2017, 06:40 PM | #3 |
It works extremely well
01-23-2017, 07:33 PM | #4 |
Drives: 2010 Camaro SS Join Date: Dec 2006
Wow. Great news. Thanks for sharing your review of this. There's a market out there for higher output return less systems. Maybe Vaporworks figured this out...
01-24-2017, 05:25 AM | #5 |
Drives: Red Jewel Camaro SS Join Date: Mar 2014
Glad to hear. Nice to have options.
BTR LSX388,AGP Twin Turbo.6L90,GM 9.9" Diff.Fore Innovations Level 4 fuel system.Great fuel economy !!!! 1xxx RWHP
01-24-2017, 07:35 AM | #6 |
Drives: 2010 2SS RS Join Date: Dec 2015
Very interesting, thanks for sharing. Any trouble codes you had to deal with? Or smooth sailing the entire way?
2010 SS RS "Cars are meant to be driven, enjoy the ride!!"
01-24-2017, 10:52 AM | #7 |
Too much is never enough!
Drives: AGP TT SS [COTW] 4/20/15 Join Date: Feb 2014
If you don't mind, how much did it set you back?
AGP TT kit, 54/57 Forged rotating assembly, Custom grind cam... Dual nozzle meth, ID850's, Livernois dual fuel pumps, ECS BAP, 25% UDP, 3 inch Magnaflow catback with X pipe, Mantic 9000 clutch, DSS 1000hp axles, DSS aluminum driveshaft, ZL1 rear end, solid subframe bushings, HE differential offset bushings, BMR Trailing arm, BMR toe rods, Lingenfelter LNC-2000,SJM Line Lock. 747 whp 714wtq
Build thread http://www.camaro5.com/forums/showth...55#post8107855 |
01-24-2017, 01:41 PM | #8 |
01-24-2017, 01:42 PM | #9 |
01-24-2017, 11:31 PM | #10 |
Not bad at all! Sent from my iPhone using Tapatalk
01-25-2017, 01:57 PM | #11 |
Drives: 2013 Camaro SS Turbo Join Date: Apr 2014
Very nice numbers, glad to see it come together congrats man
01-25-2017, 02:04 PM | #12 |
01-25-2017, 02:33 PM | #13 |
Drives: 2012 2SSRS Vert, Black w/M6 Join Date: Jan 2013
What are you running for the feed line? and did you just end up capping the return line on the hat?
01-25-2017, 08:11 PM | #14 |
