01-03-2017, 12:52 PM | #1 |
Drives: Hyper Blue 16' M6 1ss Join Date: Dec 2015
Code P0174 - Bank 2 system is too lean
I had this code pop up yesterday and i am trying to figure out the cause.
Mods are the following: MSD intake ARH 2" headers and high flow cats E85 kit and tune Could this be a intake leak, header leak or something else? Also, anyone in the Houston area have a HP tuners so i can get a data log? Thanks |
01-03-2017, 01:21 PM | #2 | |
Drives: 2016 Camaro SS Join Date: Oct 2016
Is there anyone in his area that would be willing to help out? Thanks! Tim |
01-03-2017, 01:30 PM | #3 |
i really want to start ruling things out today. I will post a video this evening to see if anyone thinks the car might have a exhaust leak. Maybe headers are tightened enough or the gaskets are leaking. Installer said he reused the stock gaskets from GM, not the ARH provided ones.
I will also get some intake manifold cleaner and spray around the intake and hoses to see if there is a rise in RPM. I am not sure how i can tell if the MSD intake manifold it self might be causing issues. |
01-03-2017, 01:45 PM | #4 |
Drives: 2016 Hyper Blue 1SS Join Date: Jul 2015
I had same code, cleared it, tuner checked out the data logs, no problems. No codes since and I beat on my car daily.
1ss/Auto-Hyper Blue
acs carbon flash spoiler, bmr springs, gm clear tails. Texas speed cam, 223/227 .635/.635 116 LSA, Kooks Long Tube Headers with green cats, MSD Atomic Air Force Intake, CAI Cold Air Intake, QTP cutouts. 503 hp Best so far 11.5 at 123 with a 1.83 60ft. BMR lower and upper trailing arms and upper control arms,E85 DELIVERED 12/29/15 http://youtube.com/bybcous " no talking only racing on my youtube" |
01-03-2017, 01:51 PM | #5 |
My car is running rough too.
01-03-2017, 02:17 PM | #6 |
It's likely loading up on fuel.
Tim |
01-03-2017, 02:40 PM | #7 |
After looking around i noticed i have some bolts missing on my MSD intake manifold. Could this possible cause the issue?
01-03-2017, 02:41 PM | #8 |
These would be at the front of the intake near the throttle body.
01-03-2017, 02:42 PM | #9 |
It looks like it was never installed on the last pic. A leak between the two halves would definitely cause a problem.
Tim |
01-03-2017, 02:47 PM | #10 |
MSD is mailing me the bolts. Is there some kind of temporary fix i can do?
01-03-2017, 03:06 PM | #11 |
01-03-2017, 03:06 PM | #12 |
Pull one out and go to Lowes/Home Depot. Get a bolt that is same length /thread in the specialty section. Grab some washers.
02-07-2020, 10:44 AM | #13 |
Drives: 2016 2ss Camaro Join Date: Oct 2013
I know this is old but I had the same code and it was a bad 02 on the drivers side. PO171 would indicate a bad o2 on the passengers side.
HBM 2016 2SS A8 NPP
427 Pray Head/Cam/Converter, Pray Ported Highram, 103mm TB, Pray Tuned, 3030 Drag Pack, Roark OTR CAI, TSP Headers, E85, UDP Best times 1/4 n/a 9.23@146.96, 1/8 5.91@118 |
