Old 12-13-2016, 12:11 PM   #1
jwober
jwober's Avatar
Drives: 50th Anniversary 2SS M6 Convertible
Keyless Ignition Car Theft
Has anyone else seen this.
http://www.autonews.com/article/2016...tton-ignitions
I sure would like to know which cars they got into and which one they couldn't
2017 2SS M6 H50 Convertible 1 of 158 (US)
1100 8/05/16 | 2000 8/08/16
3000 8/10/16 | TPW 9/5/16 8/13/16
3100 8/26/16 | 3300 8/30/16
3400 8/31/16 | 3800 9/8/16 PS#2293
4B00 9/10/16 | 4200 9/13/16
5000 & 6000 9/14/16
jwober is offline   Reply With Quote
Old 12-13-2016, 12:14 PM   #2
I`m Batman
I`m Batman's Avatar
Drives: 2016 Camaro SS M6
If you park your car outside, just put your keys in one of these Faraday bag when you get home (or work)...
https://www.amazon.com/Ska-Direct-An...ds=faraday+bag
I`m Batman is offline   Reply With Quote
Old 12-13-2016, 12:17 PM   #3
Hock23
Hock23's Avatar
Drives: Black 2016 RS
Well this is reassuring.....
Hock23 is offline   Reply With Quote
Old 12-13-2016, 01:29 PM   #4
Lurkertill03/10/2016
Drives: Soon to be a Camaro
Every car is programmed differently to pick up on different frequencies with it's remote censors. This article is using a broad brush to paint over every car out there.
Only thing we as consumers can do is protect our investment / passion / asset / the best way we can, ensure we have proper insurance coverage and hope the manufacturers address and recall cars with a potential loophole in their codes. As the saying goes, worrying will make you an old man so do the exact opposite fellow car lovers.
Lurkertill03/10/2016 is offline   Reply With Quote
Old 12-13-2016, 01:54 PM   #5
COmaro
Drives: Many
A thief with the "Mystery Device" can pick up your signal when you walk out into a parking lot. They just park a van in the middle of a mall parking lot with the device inside, and video the cars for which they pick up the signal. Then they just try to find where the car is parked later on. Or, if they can get away with it, they unlock the car while you are gone and go through the console and glovebox for a piece of mail or registration document with an address on it. This is the reason that Colorado started giving you two registration documents - one to keep in your car, that does not have an address on it, and one to use when you need a registration document with an address on it.
COmaro is offline   Reply With Quote
Old 12-13-2016, 02:14 PM   #6
TimmyTurner
Drives: Matte Black 2016 Camaro SS
Check here, this is old news. (https://www.wired.com/2016/03/study-...ignition-hack/)
Also check here to start learning to build your own little device: (http://www.rtl-sdr.com/unlocking-alm...dr-or-arduino/)
TimmyTurner is offline   Reply With Quote
Old 12-13-2016, 02:32 PM   #7
Sooks569
Drives: 2016 Camaro 2SS
https://youtu.be/dvmSOEKfkug
Sooks569 is offline   Reply With Quote
Old 12-13-2016, 02:34 PM   #8
16Panther
16Panther's Avatar
Drives: 2016 RS
What I don't care for in the story is that they have no proof its ever happened or how often. I'm not convinced car thieves would be this sophisticated.
For example, we had a '95 Civic that could be driven away with zero damage simply by unscrewing 2 Philips head screws holding the bottom of the steering column on, then the two holding the key insert to the ignition switch and then simply turning the switch.
I could do it in less than two minutes but I'm sure the 2x thieves did it they couldn't be bothered to use the screwdriver as anything but a pry bar. If they'd taken a moment to think it through they could have simply unscrewed the key insert, replaced it with a ~$45 replacement including keys from Honda and been all set.
When my stuff has gotten stolen or broken into all signs point to drug addicts looking for something to joy ride in and then contents to quickly pawn.
If they ever got their hands on a "mystery device" it, too, would end up sitting down at the pawn shop.
16Panther is offline   Reply With Quote
Old 12-13-2016, 03:01 PM   #9
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
The vast majority wouldn't, but some would. Especially if its fast and draws little attention.
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 12-13-2016, 03:02 PM   #10
jwober
jwober's Avatar
The Today show simulated it happening, last week. I'll see if I can find a link and post it.
5000 & 6000 9/14/16
Old 12-13-2016, 03:04 PM   #11
keon718nyc
Drives: Challenger SP Shaker/Arcadia Denali
As old school as it may sound just buy a CLUB for the steering wheel and when they get in the car and can't turn it that would be that if your worried about it....
keon718nyc is offline   Reply With Quote
Old 12-13-2016, 03:05 PM   #12
DGthe3
Moderator.ca
DGthe3's Avatar
I think his point was about actual car thieves doing it to steal cars, not 'white hat hackers' proving it can be done.
Old 12-13-2016, 05:53 PM   #13
jwober
jwober's Avatar
Why did this get moved to Corvette7 when I started it in Camaro 6. I am concerned about my Camaro not Corvettes
5000 & 6000 9/14/16
Old 12-13-2016, 08:26 PM   #14
h422694
h422694's Avatar
You can defeat a club with a hacksaw in less than 5 seconds. Since most steering wheels no longer have metal in them, you just cut that. Then pull the club out of the way.
Saw it on TV years ago.
h422694 is offline   Reply With Quote
