11-21-2016, 03:57 PM | #1 |
Drives: 2010 Camaro LT V6 Join Date: Nov 2016
How to replace coolant temp sensor
I took my 2010 V6 Camaro in for a coolant change yesterday at a local auto shop. As soon as I got on the freeway going home, I got a check engine light on for engine overheating.
There were no problems before the shop changed the coolant, but they deny all responsibility for any coolant issues. They think it's the sensor because they checked the actual temperature and was not overheating, which points to a bad sensor. I bought the part online today to replace myself since it's $20, but I'm having trouble locating it. I did see a couple diagrams online, but I still can't find it. Has anyone changed this part out, or can help me find where it is? the diagram shows it on the driver side, side of the engine. I took some pictures, but need further guidance on where this sensor is. |
11-21-2016, 08:59 PM | #2 |
Built Not Bought
Drives: 2010 Twin Turbo LFX Join Date: Jun 2016
its to the right of the oil filter ill take a pic
2010 Twin Turbo LFX
In Memory of my DAD Gone but never Forgotten 2014 "Built Not Bought!' Sponsors: OverKill Motorsports |
11-22-2016, 10:06 PM | #3 |
I believe I found it, but not sure how to access it.
I tried getting a 19mm wrench down there and the oil dip stick and some other hoses are in the way. Is there a step by step for removal? Also, once removed, will the coolant leak out? |
11-22-2016, 10:25 PM | #4 |
Drives: 2013 ZL1 Triple Black Vert M6 #5591 Join Date: May 2013
Gonna probably leak a little. I would check my fuild level again and check for air in the system. Unless the problem was there before you had it serviced. Just a thought. Run the car with radiator cap off for a good 10 minutes and purge the system. Good luck
695 RWHP / 660 RWTQ @ 13.5 PSI
Dyna-Tech Headers Ceramic Coated w/Super Flo Cats, JRE Custom Rough Idle Racing Cam Package and 125 RWHP Pulley Kit w/ 28% pulley, Custom Tune by Ted, ID850 injectors, JMS Fuel Booster, NGK Plugs, MSD Plug Wires, Roto-Fab CAI, Roto-Fab Big Gulp, Elite Catch Can, Mild to Wild, 90mm VMaxx Ported Throttle Body, Skip Shift Elim., D3 Coolant Resevoir, Separated Clutch Resevoir, and Fuzzy Red Dice.. |
11-23-2016, 09:28 AM | #5 |
Does anyone know the steps to access this, or is there a special tool I need? I can't reach it with a regular wrench, too much stuff in the way down there.
11-23-2016, 09:52 AM | #6 |
Drives: 2SS/RS L99 BLACK Join Date: Apr 2010
I have a feeling you should double check coolant level first, it could be coincidence that it failed after being serviced but I wouldn't bet money on it.
11-23-2016, 12:54 PM | #7 |
Drives: 13 Camaro Join Date: Oct 2016
I was thinking it probably has an air bubble in the system. That it probably wasn't bleed well enough. I agree with you that it would be just to odd for it fail exactly when the flush was done. Not that it couldn't, but so not likely.
12-09-2016, 02:19 AM | #8 |
MM.CC
Drives: 2010 Camaro 2SS LS3 Join Date: Jan 2011
Remove senor plug, then use an extension and a deep socket 19mm to remove. It seems like you can access it without removing anything. Use a swivel adapter if possible to get more access good luck. Btw its the shops responsibility to find out why its overheating . They were the last people to service the car. Dont take your car to a low tier shop a reputable shop would try to fix this simple problem
2010 camaro ss: Volant cold air intake, BBK Shorty Headers, JBA offroad midpipes, Diablosport tuned (custom tune), SLP II loudmouth axleback, ZL1 Short shifter, nitrous outlet wet "100 shot"
12-09-2016, 09:10 AM | #9 | |
Resident nomad
Drives: 2014 Summit White 1SS/1LE Join Date: Nov 2015
Sold:
2007 Z06 2002 Viper GTS/ACR 2003 Z06 1965 FFR Cobra 2012 Nissan 370Z ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing. |
12-09-2016, 05:00 PM | #10 |
Drives: '10 Black/IOM Camaro SS/RS Join Date: Mar 2010
You probably have air in the system. Highly doubt the sensor is bad
2010 Camaro 2SS/RS Black/IOM //// 1998 Pontiac Trans AM 819 RWHP @ 12 PSI (Turbo)
11-04-2019, 12:26 PM | #11 | |
Drives: 2010 camaro LS Join Date: Aug 2019
Has anyone found a way to remove the sensor
I tried using a deep socket but the oil stick would be in the way, is there a special tool I don’t know about? The engine light is giving me a code for the sensor Last edited by Leo155; 11-04-2019 at 12:27 PM. Reason: Wrong info |
