11-07-2016, 06:35 AM | #1 |
Drives: 2011 Camaro 2SS L99 Join Date: Oct 2016
Lowering springs
anyone ever used these lowering springs? http://www.phastekperformance.com/20...o-50778-77.htm
11-07-2016, 08:47 AM | #2 |
Drives: 2015 Z/22 Join Date: Aug 2015
I'm no expert but a drop like that seems a bit much. The further you go the more you change the original suspension geometry and more stress you put on the factory shocks. Someone else can probably give a better/more thorough explanation. If you want to lower that much you'd probably be better off with coil-overs.
11-07-2016, 08:47 AM | #3 |
Drives: 2012 1LT Join Date: Nov 2015
That's a fairly deep drop. 1.25" is about it, unless you're doing some wheel/tire change too.
11-08-2016, 01:49 PM | #4 |
Drives: Race Car Join Date: Sep 2009
That's a very deep drop - If you have a Squared Set-up or ZL1 Wheels, I think you will rub.
