11-04-2016, 04:39 PM | #1 |
Drives: '16 Red hot M6 Join Date: Apr 2014
Took car to dealership for a few things..
So on Wednesday night I took my camaro to the dealership to get my first oil change and such, update to android auto and take a look at the rubbing noise coming from the back when turning left, mainly after cold starts. The first service was done and I completely forgot that it's a different process to get staggered wheels rotated so now my tire letters are going to be on the inside, I guess I'll have to buy more lol. Now for the mylink update thing...this is where the problem is. They called on thrusday to tell me that the module locked up so they had to get a new one and replace it this morning. I was cool with it until they called me today and told me they didn't know what was going on. The mylink would not shut off after turning the car off and that they had to disconnect the battery so it won't get drained everytime...now I gotta wait til Monday. Has anybody had this problem or does my dealership not know what they're doing???
And finally they took my car for a 4 Mile drive to try and replicate a noise that happens only when you turn left...and then on top of that the keep telling me they don't hear anything. I'm trying to have them replicate it so they try and fix it with out me having to tell them to do flushes cause i feel they'll try to charge me for them or try to say it's normal. I'm having camaro withdrawal. Maybe I just needed to vent but if anyone has any advise feel free to chime in. |
11-04-2016, 04:41 PM | #2 |
Retired from Car mfrs....
Drives: 2LT RS/HR-V Join Date: May 2013
Idiots...they bricked the system doing an update, most likely they interrupted the power mid update. Find another dealer first, then burn them on the survey you get in a few weeks....
11-04-2016, 05:13 PM | #3 |
Drives: 2016 2SS Convertible Join Date: May 2012
I'm not sure why your letters will be on the inside after rotation. The Goodyear tires aren't unidirectional so they will just swap the wheels/tires from side to side. The tires will spin the other direction after they are rotated but the outside will stay facing out after rotation.
11-04-2016, 05:40 PM | #4 | ||
11-04-2016, 08:52 PM | #5 |
Drives: 2016 Summit White Camaro SS (2SS) Join Date: Oct 2016
Took mine in Weds. to fix the glitchy MyLink system. They call me Thursday and say they couldn't get to it so they'll work on it today. They call me today and say they have to work back and forth with Chevy to try and fix it and I won't get it back til Monday. No 'maro for the weekend. *RAGE*
11-04-2016, 08:57 PM | #6 |
Drives: 2011 2SS/RS LS3 Join Date: Nov 2011
Well, the tire rotation has been known to get screwed up. Before you drive it off, make sure the staggered set-up is correct....(Wider wheels in the back, narrower wheels in the front)....Good luck.
Personally, tire rotation on a staggered set-up is more trouble than it's worth.....side to side only?....The risk of a mix-up at the dealer wouldn't be worth it to me.... |
11-04-2016, 09:28 PM | #7 |
I know what you mean, the weekend is the only time I get to drive it, this is the first weekend without it
And now that I remember...I have wheel locks on... and he told me they rotated them...and I didn't leave the key with them or whatever it's called...somethings fishy..... |
11-05-2016, 02:10 AM | #8 |
Drives: Wd1ss Join Date: Nov 2016
The rubbing noise is probably your rear diff fluid . It needs to be changed after break in. Mine was making the same noise when cold. Changed fluid and it noise was gone. My dealer didn't even know about it. I'm sure theres a ton of guys on this forum pissed about the rear diff as I was.. good luck..Ps you must use the gm stuff dex ls 75w 90 with friction modifier don't waste your money on other gear oils like I did
11-05-2016, 05:59 AM | #9 | |
Drives: 2016 Camaro 2SS Join Date: Jun 2016
Regarding the MyLink update when I had brought mine in to the dealer a few months ago they would not do it - there was a message the dealer received from 'the powers that be' to absolutely not do it, even if requested. There was some reason they gave, so what happened to you might be related. |
11-05-2016, 08:04 AM | #10 |
@negative Ive never changed rear differential fluid before, is it difficult?
@Allez I'm not sure what it is but when I told the sales rep about updating, he looked at me like as if I spoke a whole nother language to him. Should seen the red flags there. And for the wheel locks , I bought them off amazon. The black gorilla locks. I mean it does matter if they did or not, the car only had 3600 miles on it so it's not necessary yet i don't think |
11-05-2016, 08:49 AM | #11 |
Drives: 2SS Join Date: Sep 2016
Yeah me too only on cold starts when I turn left or right there is a noise like some metal and rubber are rubbing, I thought it was a steering system issue. Is the rear diff fluid really causing this noise?
11-05-2016, 10:36 AM | #12 |
To bolts on diff housing...all u need is a 3/8 ratchet. And a pump to pump the new oil in. You can get the pump at any auto parts store I believe. Takes 10 to 15 minutes save yourself 200$ from the crooks at the dealer...fluid changes aren't covered under warranty..use jack stands or car ramps which is easier..and I'll say it again Do NOT use any else but the gm stuff it's called dex ls 75w 90 with friction modifier. Order it online it will be way cheaper then the dealer.
11-05-2016, 10:42 AM | #13 | |
Blessed ❤️
Drives: 2017 1LT RS I4 Join Date: Sep 2016
2017 1LT RS I4 A8 BLACK ON BLACK
Kindness and compassion #OthersFirst |
11-05-2016, 10:44 AM | #14 |
Drives: 2011 Camaro SS Join Date: Apr 2013
If you read the sidewall and don't see any arrows or references to the rotational direction of the tire, it's not a directional tire. My Goodyear Eagle F1's have a ton of arrows etched in them pointing in the direction of their intended rotation as a warning.
