Go Back   CAMARO6 > Engine | Drivetrain | Powertrain Technical Discussions > Transmissions
BeckyD @ James Martin Chevy
Old 10-28-2016, 07:14 AM   #1
Turbo8u
Motorhead
Drives: 2016 Camaro Convertible 2SS
2016 Clutch Bleed?
Ok, I have been researching this and I am struggling.
I see all these pictures online of the TR6060 that we have in the 2016 Camaro and I see that they show the clutch pressure line sticking out the side of the case.
But when I went under my 2016 SS I do not see this. the bell housing is SOLID!
like this,
Where is the bleeder on our trans? Is this why the guys racing these cars pull the trans out to do "reliability updates" by adding a bleeder?
Any help will be appreciated.
Cars in the stable right now.
2016 Camaro SS Convertible Nighfall
2013 Dodge Charger SRT8
2002 Chevrolet Quad Cab Duramax
2012 Jeep Wrangler Rubicon BUILT, Supercharged
1969 Camaro FAKE Z28
1968 Ford Bronco Rockcrawler
Turbo8u is offline   Reply With Quote
Old 10-28-2016, 07:40 AM   #2
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Interesting...I mean there HAS to be a way to bleed the fluid if you swap it out? Is there a remote bleeder someplace maybe?
Old 10-28-2016, 07:48 AM   #3
Turbo8u
Motorhead
That is my way of thinking......
Old 10-28-2016, 07:58 AM   #4
Turbo8u
Motorhead
I wonder what they mean by this.
Another task completed was removing the T6060 transmission for standard race prep and durability and then reinstalling.
https://theblock.com/news/wheel-whee...-tells-you-how
Old 10-28-2016, 08:22 AM   #5
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Probably just swapped out to a race clutch...
Old 10-28-2016, 09:02 AM   #6
Turbo8u
Motorhead
I was wondering if they changed the bellhousing so that they could bleed the thing!
Old 03-04-2017, 11:48 AM   #7
glamcem
glamcem's Avatar
Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold)
any update on this ? I wonder if someone was able to bleed the clutch or install a remote bleeder. Is it true that there is no bleeder hole/plug?
glamcem is offline   Reply With Quote
Old 03-04-2017, 08:21 PM   #8
1LE caSSper
1LE caSSper's Avatar
Drives: White 1LE
Correct there is no bleeder cap on trans nowadays to my knowledge.
The process is swap the brake fluid entirely - clutch fluid & brake fluid share the same tank....
If ur clutch lever is light or limp <if you bleed the brakes manually & the fluid level drops to low & air gets into the system> the process to restore it is
1 - unscrew the brake fluid cap, leave it uncovered
2 - be sure the tank is full & no leaks under the car
3 - literally pump the clutch pedal 1-200 times it will eventually come back under pressure
3.5 - If it doesn't come back after a couple hundred pumps BLEED the furthest lines from the fluid tank , passenger rear brake caliper. Then start the process all over it'll come eventually
1LE caSSper is offline   Reply With Quote
Old 03-04-2017, 09:00 PM   #9
travislambert
travislambert's Avatar
Drives: '17 ZL1
I fabricated a custom cap for the clutch/brake fluid reservoir with a hookup for a vacuum pump. Then I just let the vacuum pump do the work.
I had to pump the clutch a couple times and I also gave the inline clutch valve a little shake (just above the clutch pedal). The air came right out.
(I'm thinking the GM tech manual is where I got the idea. If I remember correctly it says to hook a vacuum pump to the reservoir.)
travislambert is offline   Reply With Quote
Old 03-04-2017, 09:02 PM   #10
X25
X25's Avatar
Drives: '16 C7 Z51
Assuming it's the same Tremec 6060 as fifth gen, bleeder line is at the top, accessible by a small port on the driver side. I had to loosen the mounts to be able to reach with my hands at the time to install a remote bleeder. I also had to put my phone up there, and take pics to see how I can install the bleeder. Those cables with a camera (or fiber flass viewing devices) would help a lot.
'16 Corvette C7 Z51 1LT (Build Thread)
'14 AGM 1SS 1LE [COTW 11/17/14] (Build Thread) (SOLD)
'13 Mazda MX-5 Club (Build Thread)
'17 RAM 1500 Crew Cab 4x4 Night Edition
'15 Nissan Rogue S AWD
X25 is offline   Reply With Quote
Old 03-04-2017, 09:03 PM   #11
travislambert
Drives: '17 ZL1
Oh.. and the bleeder is there. It's just really hard to see and you have no chance of reaching it.
(I'm positive it's on the passenger side on the 6th Gen.)
Old 03-04-2017, 09:07 PM   #12
travislambert
Drives: '17 ZL1
Here's an actual picture from my SS.
Old 03-04-2017, 09:08 PM   #13
X25
X25's Avatar
Drives: '16 C7 Z51
From my build thread:
The pics are taken from the access port at the driver side, right by the tunnel heatshield, at the very top.
Originally Posted by X25 View Post
The OEM bleeder, and its replacement. It's mind boggling why Tremec would leave the bleeder like that. If they made it a little longer, and perhaps make it bende 90 degrees down with the bleeder valve at the tip, we would not need this mod.
I'll need this in 7/16" size. I put zip ties to the tools, OEM bleeder, etc. to make sure I don't drop them into to the transmission.
Here is the hole. The clutch looks pretty clean, in good condition; no leaks, etc.
With the new bleeder on
Re-used the tabs from the discarded transmission line and it worked great!
I could even re-use the tabs between lines:
Old 03-04-2017, 09:18 PM   #14
glamcem
glamcem's Avatar
Thanks for the pics and info. I am surprised that this hasn't been discussed or documented here before (Gen 6 forums) I have a feeling it's the same exact design so the bleeder plug should still be at the very same location
