Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > Exterior Parts & Accessories
Old 08-01-2016, 06:43 PM   #1
ajohnson
Drives: 2010 Camaro 1LT
H&R adapters
Have a set of 4 H&R 25mm Adapters. Everything is there, You will just have to buy a couple extra lugs which are around a buck a piece at a local Auto store.
$150 for all four! They were more then that for just two when i got them.
Please PM with your name/number so I can text you, as I don't frequent this forum enough to respond back and fourth with PM's.
Thanks!
Alex
ajohnson is offline   Reply With Quote
Old 08-12-2016, 12:51 AM   #2
mwiteck01@gmail.com
mwiteck01@gmail.com's Avatar
Drives: 2014 2SS/RS
What do ypu mean by 25mm adapters. Are they a 25mm outboard wheel spacer? Let me know. Thanks
mwiteck01@gmail.com is offline   Reply With Quote
Old 08-13-2016, 05:36 PM   #3
Thunderfury
Thunderfury's Avatar
Drives: 2011 2SS/RS L99
What I assume he means is since it is most likely a hub centric spacer, it is known as an adapter instead. Meaning it has additional studs added to it, instead of a non-hub centric spacer which is just a disc of metal with holes in it. For those looking, 25mm is the most narrow spacer you can go without having to trim the ends of your leg nut studs down. It will sit pretty flush with a stock height Camaro, but if you lower it you may run into clearance issues.
On a side note, I wish these were 20mm because I would be ALL over them, but my car is lowered so 20 is as wide as o can go without issues. Best of luck to the seller on a good quality product for a really good price.
Thunderfury is offline   Reply With Quote
Old 08-16-2016, 04:09 PM   #4
My Caroline
My Caroline's Avatar
Drives: Black 2011 Camaro LS
I am lowered running stock 20s and 25mm adapters no issues
White Fender Hashes from Big Worm Graphix with Custom White Bowties
GM Factory Remote Start and Factory Key Fob
SS Fascia, Factory RS HIDs, Plasma P13W fog lights
Non-RS to RS and fog light harness by Gen5DIY
LED Interior, Trunk, and Licence Plate lights in white
ZL1 Spoiler with Gen5DIY harness
Factory NPP cat back
Blacked out tail light bezels
Factory 20 inch wheels wrapped in Nitto Motivos
Lowered 1.25inch on Eibach Pro springs
My Caroline is offline   Reply With Quote
Old 08-28-2016, 05:43 PM   #5
ajohnson
Old 08-29-2016, 01:53 PM   #6
AnUnarmedMan
AnUnarmedMan's Avatar
Drives: 2013 LS
Meow meow meow.
AnUnarmedMan is offline   Reply With Quote
Old 08-29-2016, 02:46 PM   #7
Davidd_SS
Davidd_SS's Avatar
Drives: LSX FTW
IMO 25mm is the best way to go for adapters
Davidd_SS is offline   Reply With Quote
Old 09-04-2016, 08:20 PM   #8
cj04
cj04's Avatar
Drives: 2010 2ss/rs
Still available?
Sent from my Nexus 6 using Tapatalk
cj04 is offline   Reply With Quote
Old 09-29-2020, 11:14 PM   #9
Camarobychance
Drives: 2014 AGM 2SS RS 1LE
Long time Ik but still have them?
Camarobychance is offline   Reply With Quote
