Old 06-21-2016, 03:22 PM   #1
Moreair1
Moreair1's Avatar
Drives: 2011 ss convertible
Final results ls3 vs coyote 10k build
Interesting article atleast I think
http://www.lsxmag.com/tech-stories/e...-the-winner-is
Cai intake and a few other mods😎
Moreair1 is offline   Reply With Quote
Old 06-21-2016, 05:22 PM   #2
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2021 zl1 a-10 WildCherry
Notice they did not do a break down on the LS engine and its costs so here it goes:
Cheap LS crate engine complete: 6500-7500
Ported stock GMPP heads $1250
Springs for cam $300
Cam GMPP LSA which is mild...$ 400, should have went ASA....
Various: head bolts, gaskets, balancer bolt, fuel rails, oil pump, chain dampener, better chain. ? 500$
SO the GM uses a new engine, new heads compared to a used ford...WTF
And it still kicks it ARSE royally with the weak stock Blower cam......
Just goes to show, Chevy rules.......oh yes and resell the stock heads with the perfectly new everything......which still would have made about the same power.
2021 Wild Cherry ZL1 A10, Sunroof, Data,Red Carbon Interior, Nav, RotoFab Big Gulp , Elite x2ultra, Borla ATAK, Driveshaft shop, BMR susp, Speed covers, intercoolers, ATI , 2650 MAG, DSX lid, 103 NW, TSP Longtubes & cats, LPE, 1le mods, ,LME cover, Katech pump and chain, Trunnions, BTR stage 2, LPE boostapump, Gforce, Speed eng , Granetteli, etc etc
Old 06-21-2016, 05:48 PM   #3
erickangulo
erickangulo's Avatar
Drives: 2014 Camaro SS
Wow. Nice.
erickangulo is offline   Reply With Quote
Old 06-21-2016, 06:04 PM   #4
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
Nice Read.
More to come.
Black_SS10 is offline   Reply With Quote
Old 06-21-2016, 08:11 PM   #5
LT1Zob
LT1Zob's Avatar
Drives: 23 LT1 / 19 Z06 / after 6 5th gens
Thanks for sharing
"Make yourself sheep and the wolves will eat you"
LT1Zob is offline   Reply With Quote
Old 06-22-2016, 01:00 AM   #6
2010reddevil
Drives: 2010 Camaro 2SS Victory Red 6M
It's a BS article and build. They wasted money in unnecessary parts. The rods and pistons didn't have to be changed out on the Coyote, and they used NSR cams but bought aftermarket springs? Dumbasses.............SMH. The test was rigged totally in favor of the LSx. I like both engines, but FFS, if you wanna compare a 5.0L engine to another, then do it against one of similar displacement, 5.3L LSx. Start with that and go from there. The 6.2L has the tq advantage of course because of the longer stroke. Longer stroke and more displacement = more tq. And to top it off, they used CNC ported heads on the LSx and didn't do ANY head work to the Coyote. Pathetic really............. I like both of them but this test was total BS. And before any swingers chime in and say, "The LSx is lighter" I don't consider 12lbs anything to mention, really. The Coyote is physically bigger, yes. But you gotta give it to Ford for making a dohc V8 that's just as lightweight as a LSx.
2011 2SS 6A Red Jewel Metallic, Vararam Tune CAI, Magnaflow 3" Competition c/b, Speed Engineering 1-7/8 LT's, Circle D 5C, M/T 275/40R20 S/S, HPTuners tune by Ryan@GPI
12.3 @ 112 ACM as of 12/22/19
Gone on 12/28/19 R I P
2010 2SS 6M Victory Red/Black (old ride)
CAI intake, Speed Engineering 1 7/8" LT's, X4 base tune, Flowmaster Outlaw axle-back.
12.6 @ 115 SAR as of 9/19/15
Gone but never forgotten.
2010reddevil is offline   Reply With Quote
Old 06-22-2016, 02:08 AM   #7
BlaqWhole
Drives: 2017 Camaro ZL1 A10
Ok cool. But which one sells more...??
BlaqWhole is offline   Reply With Quote
Old 06-22-2016, 02:39 AM   #8
2010reddevil
Last I checked, there's more Mustang's on the road than Camaro's. What's your point?
Old 06-22-2016, 06:47 AM   #9
Jasper
Jasper's Avatar
Drives: 2011 Summit White Camaro SS (LS3)
I thought the Camaro outsold Mustang year over year until the new Stang came out. Also, the Coyote didn't come out till 2011 I think (1yr after Camaro was out with 6.2L LS3) not to mention the LS3 was used in the Vette prior correct?
Would a 6.2L DOHCCoyote even fit in the Mustang Engine bay? Perhaps not and so I would say it's a fair comparison (5L v.s 6.2L) since they output close to the same power level. With that said, this is an article published by LSX mag, so it is likely biased. What's amazing to me is when I looked up fuel economy numbers and saw that even with 1.2L of extra displacement, the two engines were almost equal for consumption.
J
Mods: Vararam intake, Solo axleback, Vitesse throttle controller, Tune, 3.91's, BTR Cam, headers, hi-flow cats. NO MUFFS
Jasper is offline   Reply With Quote
Old 06-22-2016, 06:56 AM   #10
christianchevell
SO chuckles...... the test was rigged in favor of the 5.slow........... with a used engine in the parts department they must have thought it needed the pistons to make it worthy compared to a LS crate engine, oh yes and stock CNC ported heads so much more make the build they cost a extra $200........... andit was not a LSX but a common crate engine with the lame LSA stock cam.... the head work to the coyote was in the form of four friggin cams...COUNT EM. And theres more Priuses than mustangs ..... your point.
Sticking up for a rubber band, overhead cammed , Much more expensive to build 5.0 is not going to get you much for friendliness, sure they don't show the LS costs, sure they could have done them up more, sure they could use stock slugs on the coyote and work the heads, and the LS could have been used with a LSA conversion.........for that cost it so could have kicked the Coyotes arse in terms of money spent, and really blown it out of the water with FI for the LS for that cost as their money is just parts. But hey they rigged it for the coyote mostly.............
Old 06-22-2016, 07:17 AM   #11
Repooh
Certified: Slow
Repooh's Avatar
Drives: 2014 Ashen Grey 1SS/RS LS3
Red Bull gives you wiiings.
2014 Ashen Grey Camaro 1SS/RS LS3
Winter Vehicle- 2002 Subaru Impreza WRX
Repooh is offline   Reply With Quote
Old 06-22-2016, 07:21 AM   #12
Moreair1
Moreair1's Avatar
Here is the ls3 build, this was actually done by engine labs not ls magazine, I believe hotrod also ran the article
http://www.enginelabs.com/engine-tec...lding-the-ls3/
Old 06-22-2016, 09:16 AM   #13
gajagfan
gajagfan's Avatar
Drives: 2013 1SS 1LE Black - Std Exhaust
Where are the results of this test?
gajagfan is offline   Reply With Quote
Old 06-22-2016, 10:20 AM   #14
HDRDTD
This article spanned several issues. You have to go back to the issue where they detailed the LS3 build, and here it is with full details of what they did along with a complete cost list.
