Vararam
Old 06-16-2016, 01:26 PM   #1
krisprz2010camaross
krisprz2010camaross's Avatar
Drives: 2010 Camaro 2ss/Rs Transformers
2 step on 2010 ss auto?
So I recently saw someone with two step on his 2010 Camaro ss auto. I saw on Instagram. And I was wondering what part he got to make it work or is it something the tuner can do for you? I got my tune from Cunnigham Motorsports. I've seen the MSD 2 step and similar devices that you can buy to make it work, but they don't say it will work for the auto. Any thoughts? Thanks!
YouTube:Krisprz garage
Insta:kris__perez & krisprz_garage
LS3 conversion
Vararam intake(tune model)
Kooks LT headers & cats delete
Corsa ZL1 3" exhaust
RedBarn Racing Tune
CMS Stage 3 Cam
AFR CNC ported heads
MSD Spark plug wires
LNC-2000 Launch controller
NGK TR6 Spark Plugs
1le strut tower brace-TPIS spacers
Nick Williams 102mm throttle body
Fast lsxr 102 intake manifold
Slp 25% UDP
Katech Tensioner Pulley
Circle D 3600-3700 multi disk Stall
GM 3.91 gears
DDS carbon fiber driveshaft
ZL1 fuel pump & injectors
Flex fuel sensor(91/E85)
https://wheelwell.com/kris-perez
krisprz2010camaross is offline   Reply With Quote
Old 06-16-2016, 02:25 PM   #2
badcompany
Drives: 2010 Summit White 2SS
2 steps are for manual cars. plain and simple
badcompany is offline   Reply With Quote
Old 06-16-2016, 02:27 PM   #3
badcompany
if you're wanting something similar to a 2 step for your auto, id recommend a nice convertor and a trans brake
Old 06-16-2016, 02:30 PM   #4
krisprz2010camaross
2 step isn't just for manuals btw. I've seen them in person and Instagram on auto camaros. But what is a trans brake? I am planning on getting a converter and transmission cooler in the future.
LS3 conversion
RedBarn Racing Tune
CMS Stage 3 Cam
NGK TR6 Spark Plugs
Slp 25% UDP
GM 3.91 gears
Old 06-16-2016, 04:10 PM   #5
Merc
In The Circle
Merc's Avatar
Drives: 2010 Camaro 2SSRS IOM M6
If your asking what a trans brake is, I'm not sure your qualified to tell the rest of us that 2 steps are for auto's too. A 2 step is designed to release the rpm hold off a clutch pedal sensor when you leave the line. 2 steps are really designed to work properly with a manual only. BTW I has a 2step on Pumpkin.
Merc is offline   Reply With Quote
Old 06-16-2016, 04:47 PM   #6
Moreair1
Moreair1's Avatar
Drives: 2011 ss convertible
Just for fyi you can get a 2 step to work on a auto car but usually it's paired with a high stall I'll see if I can find the link to post
Cai intake and a few other mods😎
Moreair1 is offline   Reply With Quote
Old 06-16-2016, 04:56 PM   #7
Moreair1
Moreair1's Avatar
Here is a link
http://ls1tech.com/forums/forced-ind...k-results.html
It looks like it's added to make the rpms more consistent at launch
Old 06-16-2016, 09:19 PM   #8
Mr. Nasty
Emerald Coast Camaros
Mr. Nasty's Avatar
Drives: 2010 RS/SS Rally Yellow & 68 SS
For boost at the line and bring it I sooner.
Best @ 586/525 =10.41 @ 133
AS OF 12/13/14>633 RWHP =10.22@135
AS OF 1/31/15 @ 633 RWHP=10.16@135
AS OF 1/29/16 @ 633 RWHP=10.10@136
TOPED 700 PASSES AFTER F.I. AND STILL ON THE ORIGIANAL STOCK AXLE & DIFF
Mr. Nasty is offline   Reply With Quote
Old 06-16-2016, 09:26 PM   #9
Merc
In The Circle
Merc's Avatar
I set my 2step at 4800 on the leave and drop the hammer with the clutch pedal and once all bet's are off were at WOT cause the loud pedal was already on the rug.
Old 06-16-2016, 09:29 PM   #10
Merc
In The Circle
Merc's Avatar
60 foot @ 1.63 and now I have a second gear set for the 9" (457) spool and Pumpkin will be BAD A$$ down low.
Old 06-16-2016, 09:31 PM   #11
Merc
In The Circle
Merc's Avatar
On a 2step at probably north of 5000 look out. Big Thanks to DSS for all there support.
Old 06-16-2016, 09:39 PM   #12
Merc
In The Circle
Merc's Avatar
Could work if your stall is as high as a manual launch?
Old 06-16-2016, 09:42 PM   #13
Merc
In The Circle
Merc's Avatar
OK
Old 06-16-2016, 10:01 PM   #14
Merc
In The Circle
Merc's Avatar
All 2 step stuff and electronics from Lingenfelter for the M6
