Go Back   CAMARO6 > Technical Camaro Topics > Audio, Video, Bluetooth, Nav, Radar, Electronics
AWE Tuning
Old 05-31-2016, 07:19 AM   #1
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
Do you know about "transport mode"?
I don't think this is in the manual but I learned it on the corvette forum. GM allows a setting on the car to reduce the batt drain while it is going across country or just any time it may sit on the lot for months. It is also avail to you if you have to leave the car for weeks in a secure garage which is my exact situation. I'll let the tech experts tell you exactly what it powers down, but suffice to say your batt will be in better shape when you come back. For shorter periods, easier than disconnecting the batt or putting a charger on it. It works perfect.
The Camaro MAY be shipped in transport mode. To remove the car from transport mode, turn ON the four way flasher and place the driver’s foot on the brake AND on the clutch if it is a manual transmission. Press and hold the Start button for approximately 15 seconds. At this point the engine will START, but CONTINUE to hold the start button for approximately 15 seconds. Information will display on the center of the cluster that will indicate when transport mode has been turned OFF. Transport mode can be entered using the same procedure.
More info: http://sandyblogs.com/techlink/?p=997
Old 05-31-2016, 10:58 AM   #2
SSport16
SSport16's Avatar
Drives: 2016 Garnet Red Camaro 2SS
That is pretty cool...wondering how it acts if you don't take it out of transport mode.
2SS Camaro, Garnet Red, Adrenaline Red, NPP, MRC, A8, 5 Split Spoke Bright Silver Wheels (56W)
1100 Status - 7/24/15 (Ordered)
3800 Status - 10/13/15 (Built)
6000 Status - 12/22/15 (Delivered)
SSport16 is offline   Reply With Quote
Old 05-31-2016, 11:03 AM   #3
Emoto
Sure, why not?
Emoto's Avatar
Drives: 2016 Camaro 2SS, Jeep JKU Rubicon
It makes you drive like you're Jason Statham.
This is that witty and clever statement that makes you chuckle.
Emoto is offline   Reply With Quote
Old 06-02-2016, 08:05 AM   #4
SimMan
SimMan's Avatar
Drives: 2011 SIM Convertible
Send a message via Skype™ to SimMan
Does anyone know if this is also in the C5 2011.
SimMan is offline   Reply With Quote
Old 06-12-2016, 07:58 AM   #5
ender2664
Drives: 2016 2SS
Does anyone know the answer to this?
ender2664 is offline   Reply With Quote
Old 06-12-2016, 08:33 AM   #6
70454
Drives: 1970 Vette,16 1SS, 07 Ford Taurus
Thanks Glen will definitely be using this mode when my Camaro sits in my garage in the winter
70454 is offline   Reply With Quote
Old 06-12-2016, 08:37 AM   #7
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
Mine is in transport mod now for another 2 weeks, will report what works before you wake it up. Remember there is no reason to use this mode if you disconnected the battery, and/or you have it on a charger.
Old 07-02-2016, 01:32 PM   #8
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
I just came back after one month, the battery started at 12.3, coming out to transport mode after month it was 12.2, and nothing was shut off that would interfere with door unlock mode. In other words, all the doors unlocked, so you can turn transport mode off. The techs here can tell you exactly what it shuts off, but whatever it shuts off, I like this mode.
Old 10-26-2016, 02:30 PM   #9
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Bumping this one. Glen, still using this? Working well?
So to turn it on/off, it will require the car to start, then you can shut it off, no way around this huh? I just don't like having to start the car multiple times to turn it on or off...
Old 10-26-2016, 02:37 PM   #10
vet757
vet757's Avatar
Drives: ^^^This
So to turn it on, it will require the car to start, then you can shut it off? No way to turn it on without starting the car?
Im glad you bumped this, never saw this post! Very useful thanks Glen.
vet757 is offline   Reply With Quote
Old 10-26-2016, 02:44 PM   #11
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
Yup, used it all summer....my car goes sometimes three weeks without starting or moving, because I'm just doing neighborhood stuff and using the scooter. So I just put it in transport mode. The way to trigger it above is the only way I know how to do it.
Old 10-26-2016, 03:06 PM   #12
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
So to turn it off after the car has been sitting you can do this and just let the car continue to run as usual. But, to turn it on you have to turn the car off, do the procedure (which will start it) then turn it off again?
Old 10-26-2016, 03:09 PM   #13
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
Wait till your car gets here and then you can mess with it.
Old 10-26-2016, 03:15 PM   #14
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
It's not for mine (yet) I am trying to explain via text to a friend with a '16 SS how to do it, and it seems (according to him) that if the car is running, he has to turn it off, do the procedure to activate it, which is starting his car, then he has to turn the car off again...I will try it with him this weekend.
