Old 05-14-2016, 06:59 PM   #1
scandata
scandata's Avatar
Drives: 2015 2SS/RS vert, Spring Green Edtn
When to avoid a gas station
I've heard that you should never buy gas while there is a tanker filling the wells because it kicks up all the sediment that's settled at the bottom of them, and that could get into your engine. Has that been verified, or is it just playing safe? I don't know if the pumps have filters for that purpose, but unless I'm on empty I still go elsewhere when a tanker is there.
2015 2SS/RS vert, Spring Edition Green Flash (2015 - present)
2014 1LT vert, Blue Ray Metallic (2014 - 2015)
http://img.photobucket.com/albums/v692/scandata/sigpic_zpsxmxmbipg.jpg
scandata is offline   Reply With Quote
Old 05-14-2016, 07:02 PM   #2
witenite
witenite's Avatar
Drives: 2010 2SS non RS
I do the same, always heard not to fill up when the tanker is there.
Old 05-14-2016, 07:05 PM   #3
Windycity
Drives: Yellow 1le
The pumps have filters...plus your car has a fuel filter that will catch anything....i think that avoiding a station while a truck is there is kinda silly
Windycity is offline   Reply With Quote
Old 05-14-2016, 07:06 PM   #4
Welker2
Ret AF, cancer survivor
Welker2's Avatar
Drives: 2013 Camaro 2SS/RS & 2006 Corvette
This ^^^^
Welker2 is offline   Reply With Quote
Old 05-14-2016, 07:22 PM   #5
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
This X3^....
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 05-14-2016, 07:23 PM   #6
jrhagen
Drives: Camaro
You should avoid getting gas while the tanker is off loading because the gas gets aerated during the transfer. You get less gas by volume pumped. Also, the gas in the tanker is probably at a higher temperature than that in the ground. Again, you get less gas by volume.
jrhagen is offline   Reply With Quote
Old 05-14-2016, 07:28 PM   #7
Eddiefuzz
Eddiefuzz's Avatar
Drives: 2011 RS
Eddiefuzz is offline   Reply With Quote
Old 05-14-2016, 07:35 PM   #8
xnuyokr
xnuyokr's Avatar
Drives: 2012 1LT Drop Top
Funny timing for this post. I filed up my boats 6 gallon gas tank plus an additional 2 1/2 gallon container on my way to camp at the Delaware Water Gap this weekend. Motor started on the first pull. Ran down river to pick up a friend and noticed power was off a bit. He got in the boat and it bogged down then died. Checked everything, had spark and gas to carberator. Got new gas, good to go. Never had that happen before!
xnuyokr is offline   Reply With Quote
Old 05-14-2016, 07:38 PM   #9
68rssscamaro
Camaro: A Legend Reborn!!
68rssscamaro's Avatar
Drives: SOLD: 12 2SS/RS LS3 45th
There is some truth to this folks. Friend of mine has managed a gas station for years and he said the same thing--I thought he was talking s*** but he said never come here when were getting the tanks filled.
[SIGPIC][/SIGPIC]
68rssscamaro is offline   Reply With Quote
Old 05-14-2016, 07:39 PM   #10
Dizzy82
Dizzy82's Avatar
Originally Posted by Eddiefuzz View Post
Old 05-14-2016, 07:47 PM   #11
68rssscamaro
Who's the idiots?
http://www.snopes.com/inboxer/household/gastips.asp
[SIGPIC][/SIGPIC]
Old 05-14-2016, 07:55 PM   #12
deweyg63
deweyg63's Avatar
Drives: 2011 2SS/RS 500+ h.p. monster
I work at a plant that pumps hundreds of thousands of gallons of alcohol, methanol and other wonderful flammable liquids every day. The aeration part is simply not true. Temperature of the truck being slightly higher than in the ground would make a small difference but not enough to worry about in car tank volumes
deweyg63 is offline   Reply With Quote
Old 05-14-2016, 07:57 PM   #13
Avenging Orange
Avenging Orange's Avatar
And I have been putting gas in the same cars for years. Tanker or not......top tier or bottom.....and guess what? They have yet to explode or suffer performance failure. They just keep going and going and going.
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
Old 05-14-2016, 08:02 PM   #14
68rssscamaro
Why so much aeration with Diesel after a off load?
[SIGPIC][/SIGPIC]
