05-02-2016, 08:49 AM | #1 |
1st Civ. Div.
Drives: Camaroless for now...RIP "Big SexZ" Join Date: Dec 2007
Stabilitrack Issue While on Track
I was participating in an HPDE this weekend with JustTrackit at Roebling Roads near Savannah,Ga and it was a lot of fun and the weather was good as the rain held off until after the final session.
My issue that got me as I was entering onto the fast sweeping turn 9 was a message of Service Stabilitrack System which surprise to heck out of me to say the least. Within 30 seconds of receiving that message I was presented another more immediate message of Reduced Engine Power, Limp Mode. I was already past pit entrance when this occurred so I had to limp around on which felt like 4 cylinders to an emergency entrance on the backside of the track while trying not to get run over or get in the way on a hot track and this was a day after a GT350TP almost burnt to the ground from what looked like an oil fire. After getting back to the paddock area I was hopeful that the issue was not a serious one but something simple. I shut of the engine off and restarted it but it still sounds as if I'm down a cylinder only worse now so I shut it off again. I was using a BT1 OBD device for my track telemetry for my track addict app so I pull it out from the port and cycled the power. Problem solved. It sounds and feels totally normal now and I reinstalled the device to pull up any trouble codes and it was showing a malfunction of the Throttle Position Sensor Correlation. I've had a similar situation previously with my dashlogic OBD device causing my dash instruments to go crazy so I was hoping that this could be a similar fix of just removing the device but this was a new thing of going into limp mode. It took also the added step of cycling the power. Just wanted to share my incident with the community and I hope this helps someone else if they get into a similar situation. I did return to the track in my next session with no problems but I left the device off for the remainder of the day. GM did put out e technical bulletin on OBD port devices caused issues a few years ago as I remember now.
Swift....Silent....Deadly
05-02-2016, 09:06 AM | #2 |
Emerald Coast Camaro's
Drives: 2014 ZL1 Join Date: Dec 2011
If your car does it again under heavy acceleration check your plugs and wires...bet you have a plug wire that popped off
05-02-2016, 09:31 AM | #3 | |
Drives: 2013 Triple Black ZL1 / 2006 TB SS Join Date: Feb 2011
OP - Glad to hear it was solved. These cars are very finicky when it comes to the OBDII port. They rely on CAN protocol to communicate between the various on board modules and if they lose connection they usually go into limp mode or you will see several "Service -----" messages in the DIC. If this happens it doesn't hurt to pull the BCM fuse for a few seconds as well. |
05-02-2016, 09:38 AM | #4 |
1st Civ. Div.
Yeah it was the OBD port plugin device that caused the issue and the plug wires was the first thing we checked. She ran great after this issue for my next two sessions with no hiccups at all.
Thanks for the support.
05-02-2016, 09:44 AM | #5 |
Z-BEAST
Drives: 2013 JDP ZL-850 Track Spec ZL1, Join Date: Mar 2013
Thanks for sharing.
05-02-2016, 10:47 AM | #6 | |
Allergic to stupid.
Drives: 2015 ZL1 #957 M6 AGM & 1990 Z24 Join Date: Aug 2010
05-02-2016, 12:23 PM | #7 |
1st Civ. Div.
Just wanted share my experience with the community. I was hoping that you would be here for this event even though it was so close to last track night that you did here.
05-02-2016, 01:29 PM | #8 |
Allergic to stupid.
I'd like to do more events, but the budget can't support all the track days and tire expenses that go with it. Roebling Road is a fun track, but it is very hard on the left front tire.
05-02-2016, 04:06 PM | #9 |
1st Civ. Div.
Yes it is!! I started at 28 psi cold on the left front but had to go up to 32 psi to keep from rolling more of the leading edge of the tire. Lesson learned for next time.
05-03-2016, 08:29 PM | #10 |
Drives: 2013 AGM ZL1, Porsche 914, '81 GMC Join Date: Feb 2012
I've had my stabilitrac come on a few times, but the light always turns off after about 30 seconds. Also had plug wires come loose twice now...
Mods: Airaid CAI, Kooks Headers & cats, Nick Williams 102 TB, Lingenfelter 2.55" pulley, ID 850 Injectors, Elite Engineering Catch Can, Goodridge SS braided lines, Lingenfelter Pedals, Radar Projector
05-03-2016, 10:05 PM | #11 |
Drives: 02 Z06, 95 Trans Am, 2012 ZL1 Join Date: Mar 2012
Your car is modified? More boost? The problem is in the tune and can be fixed. The next time you push the car hard it will happen again. Let me guess, your code was P0068?
Bryan 2018 ZL1 M6
05-04-2016, 03:51 AM | #12 |
Go Cougs!
Let some track video please!
05-14-2016, 05:36 PM | #13 |
Here's a few snaps I got of RLHMARINES.
That car sits pretty. |
05-14-2016, 07:04 PM | #14 |
Coupe Newbie
Drives: '23 CT5-V BW, '21 Corvette HTC Join Date: Jul 2011
I know I'm bias, but the 5th Gen ZL1 will go down as the best looking Camaro every made.
