#1 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 1LT Join Date: Mar 2012
Can I delete my EGR valve?
2001 Suburban... Lately, going over bumps, my dash lights will sometimes flicker, and the car stutters and ALMOST stalls. I have discovered some sort of short around the plug to my EGR valve. Wiggling this thing around replicates the dash light/ stall problem. However, when I completely unplug the EGR valve, the problem does not occur.
What would be the harm in leaving it unplugged? Will it damage anything, harm anything, or will it simply not run as efficiently? Thanks, Ken |
#2 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2015 SS 1LE Red Hot, 1970 Chevelle Join Date: Apr 2012
I'm pretty sure EGR is part of the smog control system. You would need it functioning to pass smog.
#3 |
![]() Drives: 2016 GT350 Join Date: May 2015
Check the ground wire on the back of the passenger side head. Real common problem and causes what you are describing.
"Life is hard, it's harder if you're stupid" John Wayne
