TireRack
Old 01-16-2016, 12:00 AM   #1
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
Setting up for drag racing
What is the best bang for your buck on rear suspension to help me hook up at the track and street? Currently on BMR 1.25 drop Springs toe links trailing arms and upper control arm bushings.
I know I need my car to squat but I need it to stay there and not bounce back up.
https://www.instagram.com/whoopa_ss/
2010_camaro is offline   Reply With Quote
Old 01-16-2016, 12:14 AM   #2
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
AGP TT kit, 54/57 Forged rotating assembly, Custom grind cam... Dual nozzle meth, ID850's, Livernois dual fuel pumps, ECS BAP, 25% UDP, 3 inch Magnaflow catback with X pipe, Mantic 9000 clutch, DSS 1000hp axles, DSS aluminum driveshaft, ZL1 rear end, solid subframe bushings, HE differential offset bushings, BMR Trailing arm, BMR toe rods, Lingenfelter LNC-2000,SJM Line Lock. 747 whp 714wtq
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 01-16-2016, 12:19 AM   #3
j.curt
Drives: 2017 Camaro 1SS
I have the BMR trailing arms and springs and it helped a lot with the wheel hop. I may not be running as much power as you though.
j.curt is offline   Reply With Quote
Old 01-16-2016, 12:22 AM   #4
camarosspower
camarosspower's Avatar
Drives: 2010 camaro ss
From what I hear is removing the front sway bar. Drag radials and trailing arms with bushings along with toe rods. Lower psi on tires
camarosspower is offline   Reply With Quote
Old 01-16-2016, 12:54 AM   #5
FunkedOut
FunkedOut's Avatar
Drives: Black 2010 SS
coilovers set to high compression, low rebound up front and set to low compression high rebound in the rear.
that set up allows the front to extend easily and delays its return, while allowing the rear to squat and delaying its rebound.
not sure what else you could do for a bang/buck as you've got the rest pretty much done.
cradle bushings?
FunkedOut is offline   Reply With Quote
Old 01-16-2016, 01:07 AM   #6
Merc
In The Circle
Merc's Avatar
Drives: 2010 Camaro 2SSRS IOM M6
cradle bushings?
I worked with Jordan from JDP on spring rates for the Ridtech coilovers for Pumpkin and he says you don't want IRS to squat, but your right about the front settings for the weight transfer on the launch.
Merc is offline   Reply With Quote
Old 01-16-2016, 05:13 AM   #7
2010_camaro
So what should I do? I have the DSS axle and driveshaft upgrades. Running hoosier 295 40 18s.
Old 01-16-2016, 05:15 AM   #8
2010_camaro
So I don't want the ass to squat but I want the front to lift?
Old 01-16-2016, 07:09 AM   #9
Rockit_z28
www.1baddogracing.com
Rockit_z28's Avatar
Drives: 2010 IOM 2SS/RS Auto
Correct. The angle of the IRS in the 5th gen requires the rear to limit squat, but transferring weight to the rear of the car will help with traction. The further you squat the more severe the axle angle becomes resulting in lost power.
The heavy duty cars like Farks have moved the center section further up in the cradle to allow them to squat more without losing axle angle and power. Unfortunately in the 5th Gen, the only option to do this is to remove the gas tank and put in a fuel cell.
Hendrix Engineering has developed some off-set diff bushings that may help some of the axle angle issues.
Here is a good article on IRS: http://www.nmcadigital.com/2015/01/0...-axle-go-fast/
2010 Camaro 2SS/RS Aqua Blue Metalllic (bolt-ons)
2020 Camaro 2SS/RS Satin Steel Metallic - Shock and Steel Edition 1 of 98 - A10 (bolt-ons)
2010 Camaro 2SS/RS IOM - 1,023 RWHP 813RWTQ (Previous Paxton Record Holder: 9.82@139)
Built and Tuned by Heintz Racing
Go: DSS 9", RPM Trans TH400, Carlyle Racing 15" Conversion, ECS Vortech YSI-B, Fore Fuel System, ID1700, Gall Racing 427 C.I LSX, Mast 285CC Heads, HR Custom Cam
Show: Custom Painted Stripes/Badges (Orange Pearl over White), Z/TA Spoiler, VFN Hood, Weld Wheels
http://www.HeintzRacing.com
http://www.youtube.com/user/1baddogracing
Rockit_z28 is offline   Reply With Quote
Old 01-16-2016, 07:27 AM   #10
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Get rid of the lowering springs and go back to stock with some trailing arms.
Stock suspension will get some 1.5x 60'
Old 01-16-2016, 09:00 AM   #11
bct10985
Rear irs drag spec alignment helps
Old 01-16-2016, 09:56 AM   #12
FunkedOut
FunkedOut's Avatar
that article states that you do want squat for an IRS. even the Camaro example desired squat.
A little positive camber fixes the alignment issue so the wheels have max contact during the squat, but the axle issue is still there.
I guess it's a compromise of traction and power delivery. Seems like those offset bushings would be great for allowing more squat.
The article also stated weight on the rear is good, even ballast.
Maybe try a couple sandbags in the trunk to see if your times drop?
And the biggest rear sway bar you kind find!
Old 01-16-2016, 11:37 AM   #13
376LS3
Eh, that'll happen
376LS3's Avatar
Drives: 2010 2SS
Get rid of lowering springs and buy the Hendrix offset differential bushings. Lowering springs put even more angle on the axles than stock in which you dont want. The offset bushings straighten things out and help a lot.
2010 Camaro SS LS3 - No Modz
376LS3 is offline   Reply With Quote
Old 01-16-2016, 01:18 PM   #14
Merc
In The Circle
Merc's Avatar
Correct! Although Pumpkin is lowered I will be raising the ride height for the track with the coilovers, but that being said I can still go 11.70 and 60' @ 1.64 Bolt On's only lowered.
