Go Back   Chevrolet Corvette Stingray C7 Forum > Marketplace > Members Classifieds - Parts for sale or wanted > Autos For Sale / Wanted
Old 01-08-2016, 07:57 PM   #1
alex70olds
alex70olds's Avatar
Drives: 2012 ZL1 #141
1966 C2 needs a good home.
Modern technology and vintage looks make for the best of both worlds in Resto Modding, especially it seems when the object of one’s creative urges is a mid-year Corvette. Whether in coupe or convertible form, the original Sting Ray body style is still as fresh and exciting today as it was when introduced in 1963; when retrofitted with modern powerplants, suspension, brakes, interiors, paint and wheel/tire combinations, the results can be spectacular, as in the case of this 1966 Corvette convertible. The complete frame-off build began with the complete disassembly and preparation of the frame. All the seams were welded and the cleaned-up piece was powder coated Red for maximum durability and to match the car’s mouth-watering Red and White base/clear coat color scheme, including the Stinger stripe on the big-block hood. A 427 CI Generation 5 big block Merlin engine uses advanced Bigstuff3 electronic fuel injection to generate copious power through a close ratio M21 4-speed to a 4.11 rear end. Boyd Coddington 18-inch spoked alloy wheels are used in conjunction with power rack and pinion steering and custom Precision 4-wheel disc brakes, and shorter half shafts are employed to accommodate the car’s wider rear tires. With all those changes, the car’s appearance remains virtually stock, even in the factory-style side exhaust. That theme is maintained inside the superb White on Red cockpit, the only obvious changes being the leather wrapped billet steering wheel, Hurst shifter, White-faced gauges and billet pedals. A well done and very appealing mid-year Resto Mod.
1966 Corvette Convertible Resto Mod*
- Complete frame-off restoration*
- All seams welded and powder coated red*
- 427 CI generation 5 big block Merlin engine*
- 18" Boyd Coddington wheels*
- Precision 4-wheel disc brakes*
- Big Stuff 3 fuel injection system*
- Rear suspension 4.11 gears and short shafts*
- M21 4-speed transmission*
- Air conditioning*
- Rack and pinion steering*
- Custom paint with base color*
- Stinger hood with White stripes*
- Hydraulic clutch 1400 series
VBP Front Adjustable Transverse Monospring System
VBP Rear Adjustable Dual Mount Monospring System
Bilstein Sport Shock Absorbers (set of 4)
Addco Front 1.25" Anti-Sway Bar Kit
Addco Rear 0.75" Anti-Sway Bar Kit
VBP Rear Adjustable Smart Strut System
VBP Rear Crossmember Reinforcing Kit
VBP Rear Differential Poly Mounting Bushing Kit
VBP Rear Trailing Arm Bushing Kit
VBP T-Arm Stainless Steel Shim Kit
VBP Complete Poly Front End Rebuild Kit
VBP MIG Welded Upper and Lower Control Arms
http://i1295.photobucket.com/albums/...ps3sn4aop5.jpg
http://i1295.photobucket.com/albums/...psy6opkxcx.jpg
http://i1295.photobucket.com/albums/...psktmiz1eh.jpg
Located in Montgomery, Texas. PM for more details.
alex70olds is offline
Old 01-11-2016, 09:15 PM   #2
alex70olds
alex70olds's Avatar
Sold!
