Old 09-19-2009, 05:34 PM   #1
Dave McFly
*new car smell*
Dave McFly's Avatar
Drives: 2007 Ford Mustang 'Natasha'
Send a message via ICQ to Dave McFly Send a message via AIM to Dave McFly Send a message via MSN to Dave McFly Send a message via Yahoo to Dave McFly Send a message via Skype™ to Dave McFly
Question AC recharge question (for impala/monte owners)
Monty, needs to have the AC recharged. I got a can of the coolant and i have the hose that connects the can to the port to refill it. but i cannot tell which one is which. I have one on one of the lines just under and behind the air box on the right side of the engine bay. and i have one on the firewall just under the left wiper blade. one of my friends said that of the 2 the smaller one is the one you connect the hose 2. but on the can it says attach it to the lower line. so for any of you who have impalas and Montes (and other cars like it, grand prix, etc) where do you connect the hose to, i just want to make sure so i do not blow up my AC system .
"May the forces of evil become confused on the way to your house."
George Carlin
Dave McFly is offline   Reply With Quote
Old 09-19-2009, 05:44 PM   #2
ShnOmac
What year is your car? Just making sure it doesnt need r-134
Old 09-19-2009, 06:24 PM   #3
Dave McFly
*new car smell*
Dave McFly's Avatar
Talking
its a 2004 (shows that under my avatar ). and i have the correct stuff my dad put it in before in his impala (2001) and since this is basically a 2 door shorter version of that car the ports should be in the same place .
George Carlin
Old 09-19-2009, 06:25 PM   #4
Oldrocker
Oldrocker's Avatar
Drives: 2010 SS2/RS Victory Red
THE SMALLER LINE IS NOT THE ONE TO CONNECT TO!!!! It would be dangerous to do that. The small line is the high pressure side, you want to connect to the larger of the two lines which is the suction line. Also your 2004 Monte Carlo doesn't take r-12, it takes 134a and the fitting from the kit will only hook up to the low side. That being said, these systems are sensitive to proper refrigerant charge, so I recommend you take it to a pro that knows what they are doing and has the proper equipment to do it with. FYI it connects to the line under the air cleaner. If hooked up to the high side it won't blow up your A/C system, the can of refrigerant can blow up in your hand!
Oldrocker is offline   Reply With Quote
Old 09-19-2009, 06:33 PM   #5
Dave McFly
*new car smell*
Dave McFly's Avatar
Question
i meant to say 134, as i got the correct stuff, you cant even BUY the R12 in stores anymore. my dad's friend who runs a garage that does all the stuff we cannot do (shocks, struts, stuff like that) told me it was the smaller one near the firewall. and i have been reading different forums and all of them said near the air box (big one).
George Carlin
Old 09-20-2009, 10:22 AM   #6
duder4thgen
Drives: Bird
When in doubt, the one that gets cool/cold is your low side port, the one that gets hot is your high side. If they are both the same temperature, be prepared to spend money in the future. I'd listen to the people who own one and are saying near the air box.
Might be worth renting a manifold set from autozone so you can see whats going on with the high side pressure at the same time.
duder4thgen is offline   Reply With Quote
Old 09-20-2009, 02:36 PM   #7
ShnOmac
Arent the high side and low side different size fittings?
Old 09-20-2009, 05:49 PM   #8
Oldrocker
Oldrocker's Avatar
Yes they are.
Old 09-22-2009, 11:08 PM   #9
firestone_ss
firestone_ss's Avatar
Drives: 2010 camaro ss
i belive that can will only let you hook to the low side anyways,blue cap
firestone_ss is offline   Reply With Quote
Old 09-22-2009, 11:14 PM   #10
coolman
Guest
Pay me now or pay me alot more later. I've been doing refrigeration for along time and still can't figure out how someone thinks they can put the proper amout of freon in a car with just a can and a hose.
coolman is offline   Reply With Quote
Old 09-23-2009, 09:00 PM   #11
Oldrocker
Oldrocker's Avatar
I love it when they do though, it makes me lots of money.
Old 09-23-2009, 09:09 PM   #12
coolman
Guest
I'm with you there.
Papa John's Giving Away Free Pizza To Any Camaro Owner Tomorrow! Blue Maro Demon 5th Gen Camaro SS LS LT General Discussions 331 02-13-2012 11:29 PM
Owners manual protective cover? Tigerrag24 5th Gen Camaro SS LS LT General Discussions 14 05-06-2009 03:52 PM
question for camaro/firebird owners TFord General Automotive + Other Cars Discussion 7 02-26-2009 03:39 PM
LSX owners: AFR Cylinder Head Owners FTI-EDC General Automotive + Other Cars Discussion 0 11-10-2006 06:54 PM
