TireRack
Old 11-17-2015, 07:50 AM   #1
xinfamousxi
Drives: Camaro 1SS 1LE
I need some help driving stick
As I posted here in the past that I was learning to drive stick before I took delievery of my 1LE. Well I got it last night and drove home with it and had no issues (other than me stalling at a light and the girls next to me just looked at me weird). However, this morning while driving to work I noticed that on certain shifts it would tell me where to shift versus what I was shown.
Example: I was in second and when I went to go to third it blocked me and said fourth.
I texted my bro but he is a plane out of town so I thought I would reach out here. Thanks.
xinfamousxi is offline   Reply With Quote
Old 11-17-2015, 07:52 AM   #2
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
The skip shift is explained in the owner's manual.
If you are in a certain speed range, you are forced to shift from 1st to 4th. Take it to a higher rpm in 1st and you will be OK.
Old 11-17-2015, 07:52 AM   #3
DRKS1D3
DRKS1D3's Avatar
Drives: '17 Corvette Grand Sport M7
It is just the skip shift kicking in because you are at low RPM's. Give it a little more gas and that message will disappear, allowing to shift wherever you please.
MY RIDE: 2017 CORVETTE GRAND SPORT--TRIPLE BLACK, 7 SPEED MANUAL, VARARAM TCR-7 INTAKE, BORLA CATLESS X-PIPE, CARBON FIBER STAGE 2 AERO, MGW SHORT-THROW SHIFTER
**SOLD**2011 TRIPLE BLACK SS CONVERTIBLE--6 SPEED MANUAL, MANY MODS, 455 RWHP/435 RWTQ
DAD'S RIDE: 2012 ZL1 #1866--BLACK, 6 SPEED MANUAL, EXPOSED CF HOOD, POLISHED WHEELS, SUNROOF, ROTO-FAB INTAKE
"Silly Americans, taking from the rich and giving to the poor only works in fairy tales. Success is earned here!".
DRKS1D3 is offline   Reply With Quote
Old 11-17-2015, 07:56 AM   #4
xinfamousxi
Ah this makes sense. I have the book here with me at work. I plan on reading through it during the day. Thanks
Old 11-17-2015, 07:58 AM   #5
Welker2
Ret AF, cancer survivor
Welker2's Avatar
Drives: 2013 Camaro 2SS/RS & 2006 Corvette
Read up on the skip shift and then practice, practice, practice. Don't try to drive too aggressively until you get to the point where you're consistently shifting smoothly and at the right points. It should come naturally in no time ... good luck and enjoy
Welker2 is offline   Reply With Quote
Old 11-17-2015, 08:01 AM   #6
xinfamousxi
Lat night on the way home I was getting those little jolts when shifting, but this morning half of my shifts were really smooth, so I hope its a sign that I'm getting it.
Gas is at an Average 14 MPG right now. I hope that gets better once I'm better on the take off since that seems to eat up most of the gas. I just have to find that right grabbing spot when I let off the clutch.
Thanks!
Old 11-17-2015, 08:18 AM   #7
xc_SS/RS
Drives: 2010 Camaro SS/RS
I think if you stay in first past 20 mph or rev it past a certain point skip shift does not kick in. Try that, or order a $20 connector that stops it from locking out gears, but you'll still see the message pop up.
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 11-17-2015, 09:04 AM   #8
GotGame55
Haters gonna hate?
GotGame55's Avatar
Drives: '04 Chevy Dirtymax
Google skip shift eliminator. Had it on my '11 SS. Worked great.
'04 CCSB Duramax
GotGame55 is offline   Reply With Quote
Old 11-17-2015, 09:07 AM   #9
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 19 WRX
The first sign that you're beginning to get it is when you aren't afraid you're going to stall it coming off every single stop. Smoothing out the upshifts is more of a detail-level improvement that says your timing and "muscle memory" is getting better.
Thanks!
Brand-new cars tend to use a little more gas, at least partly due to there being a little final microscopic-level breaking in of moving parts to each other. Not just in the engine either; also in the transmission and rear axle.
Norm
'19 WRX 6M (the family sedan . . . seriously)
Norm Peterson is offline   Reply With Quote
Old 11-17-2015, 09:09 AM   #10
Ghost7997
Ghost7997's Avatar
Drives: 2014 Ultimate Track SS "Weapon-X"
Skip Shift Eliminator
GotGame55 is totally right. I just recently put one in my 2014 1LE and is works like a charm.
xinfamousxi, Just be sure to watch yourself in those low rpm's to make sure you don't stall. Also, make sure you don't give it too much gas. No one likes to see a beautiful Camaro in a ditch. Any questions on how it works, or installation, feel free to message me. Good luck!
Ghost7997 is offline   Reply With Quote
Old 11-17-2015, 09:13 AM   #11
xinfamousxi
Norm
This! Makes it worse when I start rolling backwards.
Old 11-17-2015, 09:13 AM   #12
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
You'll get it.
Just wait until you hit the advanced level where you start using you e-brake to avoid the hill assist from a dead stop!
Mods:
Old 11-17-2015, 09:19 AM   #13
spadz93
BUMBL Z
spadz93's Avatar
Drives: 2015 ZL1
You can get an eliminator for like 25 bucks. Message will still pop up but it'll disable the solenoid that locks those gears out. Install is remotely simple, just gotta get the car jacked up a bit to access the connector that the eliminator connects to
Sold: 2015 ZL1 M6, Rotofab Intake, LS3 throttle body, 2.55 Upper/9.17 Lower, Custom Camshaft, DMS Reinforced Brick, ID1050X, 1 7/8" Headers, ProSpeed HX/Reservoir, DSX Aux Pump/Flex Fuel Sensor, E85, McLeod RXT, BMR 1" Drop, 680rw 93/750rw E85, Tuned by CSP
Sold: 2010 2SS, some bolt ons, 415rwhp/400rwtq
spadz93 is offline   Reply With Quote
Old 11-17-2015, 09:24 AM   #14
xinfamousxi
Now since I'm a beginner does it make sense to maybe keep it on for now?
