Old 10-25-2015, 04:26 PM   #1
Trifecta23
Trifecta23's Avatar
Drives: 2013 Dusk 2ss/RS conv.
Battery tender?
Should I buy the jr or go for the plus? I like that the jr plugs directly into the wall. And I can buy 2 of them for the price of 1 plus.
2013 Dusk Camaro/Convertible/2SS RS/6 Speed Auto/One of Sixty Nine
jdm
Trifecta23 is offline   Reply With Quote
Old 10-25-2015, 06:40 PM   #2
Ace0751
GEN5 Detail
Ace0751's Avatar
Drives: 2011 Synergy Series 2SS Convertible
I would go for the plus but that's my opinion. Never go cheap.
Roto-Fab CAI, Borla ATAK Exhaust System, Stainless Power Headers, RX Performance Catch Can, ACS T4 Splitter, Oracle side markers, Dyno Tuned by RDP Motorsports
Ace0751 is offline   Reply With Quote
Old 10-25-2015, 06:50 PM   #3
hkittrell
hkittrell's Avatar
Drives: 2015 Camaro 1SS/RS 1LE
I use the jr. and works great for the car and two bikes. I have more than one.
hkittrell is offline   Reply With Quote
Old 10-25-2015, 07:00 PM   #4
qcman
qcman's Avatar
Drives: 2013 Camaro 2SS RDP Tuned L99
Same 2 juniors and they work great...
qcman is offline   Reply With Quote
Old 10-25-2015, 08:03 PM   #5
Trifecta23
Trifecta23's Avatar
I went with the plus. It's a big battery.
jdm
Old 10-25-2015, 08:33 PM   #6
trcsr
trcsr's Avatar
Drives: 2018 2LT/RS Conv
I have the Jr. and have never had a problem with it not being adequate for my needs including the Camaro, lawn mowers, tractor. It may take a little longer than the Plus, but I have a regular battery charger id I am in a hurry.
trcsr is offline   Reply With Quote
Old 10-25-2015, 09:03 PM   #7
joeybsyc
joeybsyc's Avatar
Drives: 2010 Aqua Blue Metallic 2SS
Jr. works great and less bulky.
joeybsyc is offline   Reply With Quote
Old 10-25-2015, 09:12 PM   #8
Shark72
Shark72's Avatar
Drives: '16 Z06/Z07, '15 Z/28,1972 Stingray
you get what you pay for....why would you try to save ten cents on ten dollars?
2015 Z/28 #642 Black Bad Ass
Shark72 is offline   Reply With Quote
Old 10-25-2015, 09:14 PM   #9
skipinminn
Chiquita
the JR is all ya need I'm on my 4th winter of storing my Car
Old 10-25-2015, 09:16 PM   #10
camguynj
camguynj's Avatar
I had both JR and Plus and neither would get my battery to full charge when the car was only a yr old, in fact they shut off after reaching their internal timer limit My car is kept in the driveway so it was a real pain having to remove the car cover in below freezing temps every few hrs to look under the hood to see what those silly lights were doing and try to figure out what they meant
I switched to a CTEK 4.2 amp tender and BAM all was good No guessing with the CTEK as it has separately labeled lights for each stage , so once it got Float mode I never had to check it again. It also has a Cold mode for introducing more volts in certain stages.
If your car is going to be kept outside I'd go with a CTEK. If inside then I guess you'd be OK with a Deltran but I'd go with the Plus as the JRs are more for motorcycle and small car batterys.
Old 10-26-2015, 09:33 AM   #11
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
I have bee using a Battery Tender Plus for 5 years. Works great.
Old 10-26-2015, 09:43 AM   #12
Normagene
Normagene's Avatar
Drives: 2013 Ashen Gray M6 ZL1
I use a Jr as well. Lots of aftermarket stuff that drains, so as soon as I pull into the garage I connect under the hood. I leave it connected all winter, summer only tires so she's in hibernation for several months.
A few months ago I left the inside lights on in my truck. Went out to start it, dead, nothing, no clicking no power whatsoever. Connected the Jr and four or five hours later it had enough juice to start.
But that was a one time thing, glad I had one, but I use it mainly on the car just to float the battery.
Normagene is offline   Reply With Quote
Old 10-26-2015, 10:17 AM   #13
chriscrash37
Drives: 2010 Camaro 2ss
I have the Jr. and have put the car away for 6 years with no issues. It works just fine and I wouldn't spend the extra money unless you are using it for other things too.
chriscrash37 is offline   Reply With Quote
Old 10-26-2015, 10:20 AM   #14
ChibiBlackSheep
ChibiBlackSheep's Avatar
Drives: 2012 2SS/RS, 1968 SS
I bring the battery inside, and hook it up to my JR in the basement. Works great!
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS
ChibiBlackSheep is offline   Reply With Quote
