#1 |
![]() Drives: 2015 Camaro 1SS RS Join Date: Feb 2015
Rear brake drag on my Regal GS
Yesterday I had to remove the rear tire on my '14 Regal GS because a bolt went through the tire. While it was jacked up I noticed the wheel was not turning freely. With the tire off, turning the rotor was VERY hard to do. You can also hear the dragging of the pad to the rotor. I checked the other rear wheel and its doing the same thing. The e brake is off. I took a video showing this. In the video I am turning the pretty hard. Is this normal ?
https://youtu.be/88FHD9TJpTI
2015 Camaro 1SS/RS Blue Velvet Metallic, L99, Airaid Intake Tube, Akebono Ceramic Brake Pads, Borla S-Type Axle Back, GM Strut Tower Brace, Range Device
#2 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 20 1LE 2SS M6 Rally Green Join Date: Mar 2014
That amount of drag isn't necessarly unusual. You could compress the piston all the way in with a c-clamp to make sure its moving freely. Could also pull the pins and lube them just to be sure. Given its only a 14 it should be ok. I'd rather check it myself than have the dealer touch it.
"the trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.” Ronald Reagan - |
