10-04-2015, 10:27 AM | #1 |
Drives: 2010 RJT 2SS Join Date: Dec 2009
91 Octane in 93 Octane tune
Currently live in Pa where we have 93 octane. My Camaro has a LS3 conversion tuned for 93 octane. I may be moving to Northern Maine next year where they only have 91 octane and plan to take the Camaro with me. Should I leave the 93 tune and use an additive or get it tuned for 91? Also does the car need to have 91 octane fuel in it to be tuned to run with it? Thanks
10-04-2015, 05:43 PM | #2 |
Drives: 2010 2SS/RS 6spd LS3 Join Date: Jan 2015
Imho... the difference would be negligible
10-04-2015, 05:50 PM | #3 |
Drives: 2014 1LE, 1996 z28 Join Date: May 2015
Get it tuned on 91 imo. Might lose 5-10hp, but you don't want to risk having detonation.
10-04-2015, 10:10 PM | #4 |
Drives: 2017 2SS M6 Join Date: Jun 2013
get it tuned for 91. Yes it needs to have all 91 in it to be tuned. put 3 tanks of 91 through it befor the tune to make sure. just dont be getting on it with the 91 and you will be fine.
10-04-2015, 11:06 PM | #5 |
Drives: 2010 Camaro Join Date: Oct 2014
I'd have a a degree or 2 pulled out under wot areas at the minimum but really it depends how aggressive it is to begin with.
2010 2SS LS3 228/235 Cam Motion custom ground cam, AI 280cc ported heads, Dynatech 1 7/8" long tubes, catless mids, CAI intake, ATI 10% UDP, CORSA cat back, Slp 160 tstat, gm 3.91s/Tru trac, EFI LIVE tuned by myself
10-04-2015, 11:22 PM | #6 |
just can't seem to leave
what's the elevation difference between where it was tuned & where you're moving?
the rule of thumb for octane is 1 point per 2500', so 93 at sea level essentially runs about the same as 91 at 5000'. that said, you should still be able to drive it fine, but it's much safer & will be more efficient to retune it.
Eve ('00 FRC): hot-air intake
Rowan ('09 H3): 5spd mom-mobile Penny ('99 Sierra): 5.3 / HD 5spd... gone but not forgotten Samson ('18 HD): compounded 408 |
10-04-2015, 11:27 PM | #7 |
Eh, that'll happen
Drives: 2010 2SS Join Date: Apr 2012
I moved from 93 to 91 and my car knocked like a mother. Just listen after a couple fill ups. If you dont hear anything, youre prolly safe. But Id bet money youll need to retune.
2010 Camaro SS LS3 - No Modz
10-05-2015, 12:21 PM | #8 |
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE Join Date: Feb 2014
Retune with 91 in the area you live with a good tuner who knows what he is doing.
OLD GUY FLYING FAST AND LOW
10-06-2015, 05:17 PM | #9 |
The altitude of Maine isn't too much different than here in Pa. My tune is fairly aggressive so I'll get it tuned for 91 before I would move. I'll just have to find a station around here that has 91 instead of 93. I think Sunoco carries it. I might talk to Ted Jannetty about a tune since we travel thru Waterbury on our way to Maine.
Thanks for all the replies! |
10-06-2015, 07:55 PM | #10 | |
