06-25-2015, 09:10 AM | #1 |
New tranny fluid = New transmission
So after way too much debate I went ahead and changed my transmission fluid this week. I had the famous "notchy feel" when shifting since new (worst was the 1-2 shift) and hoping it would just go away didn't work, after 6000 miles anyways.
A very easy job to do, it takes longer to get these beasts up on 4 floor stands so if you have a hoist it would be a dream job. The drain and fill plugs are very easy to access. To refill I bought some 1/2 clear hose (Home Depot for $4) and filled from above straight out of the bottle. I ended up using Royal Purple Synchromax High Performance Synthetic Manual Transmission Fluid, 4 quarts. The difference is incredible I wish I had done this last summer, feels like I have a new transmission. The 1-2 clunk is completely gone and all the other shifts actually feel like they are sucked into the next gear. Big difference with the cold feel as well, no more stiffness at all. Not trying to start a debate or war on what type of fluid is the best, I think they are all an improvement and everyone has an opinion. Just want to tell anyone that is on the fence about this mod, go out today and change the fluid if you have the same feel I did....you fall in love with your 1LE all over again
'14 1LE, Recaro, Cammed, Headers, Hi Flows, CAI, Tuned, 486 RWHP
https://www.youtube.com/watch?v=H57UfKCO0EY&feature=youtu.be |
06-25-2015, 09:17 AM | #2 |
American Gold Whisperer
Drives: 2014 White 1LE 2SS/RS/NPP/Rec/Nav Join Date: May 2014
Did mine at 5k, and I agree.
06-25-2015, 10:35 AM | #3 |
Drives: 2015 1LE SUMMIT WHT 1SS NPP RECARO Join Date: Dec 2014
I just picked up some Redline D4 ATF & gear oil, gonna change out this weekend. Looking forward to the results as well!
06-25-2015, 10:40 AM | #4 | |
I was going to use Redline but it much harder to find here in Canada.
06-25-2015, 10:55 AM | #5 |
Drives: 2015 Red Rock ZL1 Join Date: Dec 2014
I use a Redline additive for my diesel and love their products. Any opinion on Redline vs Royal Purple?
Alex
2015 Red Rock ZL1 Panama City Beach, FL |
06-25-2015, 12:06 PM | #6 |
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE Join Date: Feb 2014
Did mine with Redline D4 ATF the first week I had the car . Big fan of Redline . Also used Redline gear oil in the diif .
OLD GUY FLYING FAST AND LOW
06-25-2015, 12:34 PM | #7 |
Destroyed by flooding
Drives: Wife's car Join Date: Mar 2014
Redline D4 ATF here also, the difference is quite amazing!
06-25-2015, 01:41 PM | #8 |
Drives: 2018 1SS 1LE Join Date: Nov 2014
Just to confirm, switching tranny fluid yourself does not void warranty. Or does it?
06-25-2015, 02:48 PM | #9 |
Drives: 2014 Camaro 2SS RS 1LE Join Date: Jul 2014
Is there a write up for this? My tranny is driving me insane, 1st and 2nd gear are definitely ridiculous.
Also is there a write up for the differential fluid? Might as well since I could use a better ride From what i've heard, Royal Purple product is way up there in the high quality dept. Can't say i've heard of Redline |
06-25-2015, 03:02 PM | #10 | |
Alex
06-25-2015, 03:06 PM | #11 |
Another question, the royal purple says this:
Royal Purple Synchromax Manual Transmission Fluid 01512 Royal Purple Synchromax manual transmission fluid is recommended for manual transmissions that specify an automatic transmission fluid or motor oil. It is also ideal for 4x4 transfer cases and/or 2-cycle motorcycle gear boxes. Synchromax is formulated with Royal Purple's synthetic, proprietary Synerlec additive technology, which offers improved shift quality over a wide temperature range and reduced gear noise. It is fully compatible with all types of friction materials, and offers excellent corrosion and oxidation protection, without affecting the soft metals commonly found in manual transmission synchronizers. Is this okay for use in our transmissions?
Alex
06-25-2015, 03:18 PM | #12 |
I just talked to a Royal Purple engineer and he said that GM may void the warranty because this is considered a "performance upgrade"... Seems like a bunch of garbage to me but I know he's correct... Any thoughts?
Alex
06-25-2015, 04:57 PM | #13 |
Did you use the full 4 qts???
06-25-2015, 05:35 PM | #14 |
No it does not, you can perform your own service. I go to our Chevrolet web sight and document all service that was done on my car. I did this transmission a favor by changing the fluid!
