06-23-2015, 06:49 AM | #1 |
Pills are for Pansies
Drives: 2023 2SS Red Hot Vert Camaro Join Date: Jul 2008
Bose system
So,
Does anyone have any opinions on the new Bose system that will be in the 16's? I love my stock BA system - I think it's great, but is Bose that much better? |
06-23-2015, 06:57 AM | #2 |
Drives: 2018 ZL1 1LE / Nightfall Grey Join Date: Apr 2013
In my opinion for the money - I like Bose better, my BA system is pretty good, however turn up the base and it distorts a bit in my C5 - I had Bose in a few of my other vehicles and I prefer it over BA- better lows and crisper highs
06-23-2015, 07:29 AM | #3 |
Drives: Coupeless :( Join Date: Jan 2015
I honestly don't think either system is good for the money. The factory EQ settings aren't great, and the way the equipment is setup poses problems if you want to replace it with something else.
06-23-2015, 07:44 AM | #4 |
Drives: 2016 Camaro 2SS Join Date: Jan 2015
I'm hoping there is just a basic speaker/radio package so we can install aftermarket ourselves.
06-23-2015, 08:42 AM | #5 |
Drives: 2017 Camaro 2SS 6MT Join Date: Aug 2006
I'm generally not a fan of any factory stereo system, no matter who makes it or how expensive it is. There's no substitution for a really nice aftermarket system. Problem with modern cars is multiplex electronics and integration makes aftermarket head units really cumbersome to install.
What I like to do now is keep the factory setup in the dashboard, then use an active line out converter from the factory speaker outputs, active EQ from that, and then run some nice amps and speakers off that. That will really open up your sound system with clean crisp highs, full rich mids, and bass that will make the hair on the back of your neck stand up. And you can get all that for less than $2,000. Of course the sky is the limit if you want to get crazy with your sound system, but you can definitely do something for less than two grand that will trounce the factory Bose system. If you're serious about your music, forgo the Bose system and put your own aftermarket in. |
06-23-2015, 09:11 AM | #6 | |
Drives: 2016 Red Hot 2SS M6 Join Date: May 2015
The easiest way to get a huge upgrade in audio quality is to just replace the speakers. The head unit is fine, and depending on the way it's set up you might just be able to intercept the signal before it goes into the factory amplifier and do whatever you want at that point with a miniDSP and a better amp. |
06-23-2015, 10:20 AM | #7 |
Yeti's Daddy
Drives: ATS-V, Prowler, M6 V10 Join Date: Jun 2015
Bose system in my C6 works fine. It's no bowers and wilkins in my wife's Jag, but it's enjoyable enough for some music playing. If I really want to enjoy the music, I would listen to music at home, not in the car.
You'll have beautiful engine sound for your listening pleasure. |
06-23-2015, 11:03 AM | #8 |
Drives: 2018 ZL1 6M, Silverado High Country Join Date: Oct 2008
I am curious to see how the Bose system sounds. The Boston acoustics was ok nothing special
Previous Camaro's - 2002 Z28 6 spd manual, T tops, Sebring Silver - 2010 2SS 6 spd manual, Cyber Gray Metallic
Current Vehicles - 2018 ZL1 Red Hot 6 spd manual, Carbon Hood, Sunroof 2019 Silverado High Country, Daily Driver |
06-23-2015, 01:19 PM | #9 | |
I've yet to see a factory amp that strong. MOSFETs baby! |
06-23-2015, 01:49 PM | #10 |
Yes.. That's exactly what I said, you need to upgrade the amp... I'm just saying that upgrading the head unit, which is very expensive, is a very minor sound quality upgrade compared to upgrading the speakers and external amp.
06-23-2015, 02:26 PM | #11 |
Drives: 2022 F150, 87 Monte Carlo Join Date: Mar 2015
It really depends on the system. Sometimes replacing the headunit provides a good increase in sound quality. With current cars though, I would never consider replacing the headunit. There is far to much integrated with the head unit and aftermarket ones look very out of place.
06-23-2015, 02:48 PM | #12 | |
You can use something like this: http://www.crutchfield.com/S-W34L8x5...LC8i-Gray.html AudioControl also makes an integrated LOC with full equalizer for about $600.00 if you want even more precision. |
06-23-2015, 02:51 PM | #13 | |
The only thing I would say is, and I know I'm going to be laughed at, but I would want a CD player in my Camaro. I know GM has a CD player module for the ATS that installs into the glovebox and connects and interfaces directly with the factory Cadillac CUE system, like the old days when you had a CD changer in it and a cassette factory head unit. I hope GM offers the same thing for the Camaro. |
06-23-2015, 03:00 PM | #14 |
Drives: 2000 WS6 Join Date: Dec 2014
Does Bose use still wierd speaker impedances matched to their amp channels? I don't think you can just take an off the shelf speaker and expect it work correctly with a Bose HU.
