Old 06-22-2015, 11:37 AM   #1
hrpiii
AKA "Beefcake"
hrpiii's Avatar
Drives: 2023 ZL1 Sharkskin
help -quick question about E85 and wife's Sonic
The wife accidentally put E85 into her Sonic. She was not paying attention, and was just topping her car off after coming from a long trip. She only put 4 gallons of E85 in the tank. I believe the Sonic is a 12 gallon tank. She usually run 89 octane.
She is concerned about it 'hurting' any of the fuel components or engine. Is she okay, as in no problem with only that little of fuel? Or any recommendation to resolve.
I know it may run rough some, anything to ease her mind would be helpful.
Thanks
Old 06-22-2015, 11:42 AM   #2
JimE
JimE's Avatar
Drives: 2013 2SS/RS/1LE
Should be fine. Obviously it won't run well with straight E85, but a mixture shouldn't cause a problem. I'd top off again after a 1/4 tank or so. If there were to be any drivability issues, you would notice right away.
JimE is offline   Reply With Quote
Old 06-22-2015, 11:46 AM   #3
FunkedOut
FunkedOut's Avatar
Drives: Black 2010 SS
the faster you burn it or dilute it, the better.
biggest issue you'll find is the corrosiveness of it on lines/parts not designed for it.
if the Cruze is not flex fuel, it will be running lean, so I'd keep it easy on the rpm/wot
FunkedOut is offline   Reply With Quote
Old 06-22-2015, 11:47 AM   #4
hrpiii
AKA "Beefcake"
hrpiii's Avatar
Thanks. when she called the dealer, they were like "needs to come in, drain the tank, clean the fuel system... oh yeah, and it will be $350".
I was like, Let me talk to this guy? He kind of stuttered to repeat it when I said it was only 4 gallons and she was just a little concerned. Then I asked what they were replacing for $350, better be parts involved. He said that it was all labor, no parts.
Old 06-22-2015, 12:42 PM   #5
jdrop01
jdrop01's Avatar
Drives: 05 GTO
Damn that's a lot for a drain...... I just mix it and 1/4 down mix some more 89. No harm will be done.
jdrop01 is offline   Reply With Quote
Old 06-22-2015, 01:05 PM   #6
batman53201
Account not blocked
batman53201's Avatar
Drives: The Batmobile
if your really worried about it, siphon the gas out, and refill with premium.
batman53201 is offline   Reply With Quote
Old 06-22-2015, 01:22 PM   #7
hrpiii
AKA "Beefcake"
hrpiii's Avatar
Thanks guys. I have been doing a lot of "googling/reading" and get the feeling that may just run it down a little, fill it with 93, run out a quarter tank, refill it with 93 and repeat at half tank, then full tank. The engine should be fine, other than maybe throwing a CEL for a short time, but nothing 'horrific' is going to happen.
I appreciate all the input to help me feel better making that decision. If any of you guys were like "It's a time bomb waiting to explode"...then, my thought process would have been a little different.
All the reading so far, should be fine. Now if it was empty, and all 12 gallons of E85 put in, I would have probably drained to make her feel better. We all know that feeling when we do something 'bad' to our baby. Her little Sonic is her baby. She was exhausted, moms injury on her mind, only a mile from the house and was topping it off. When she called me, she was so upset, couldn't even make out what had happened. I panicked ...then moments later, was like, "it will be okay, I will come up and help".
Old 06-22-2015, 01:27 PM   #8
Destructo09
Drives: 2010 CGM Camaro 2SS/LS3
Might as well just put 87 in it, no point in wasting money on 93. Is it the 1.4L turbo? If it's a N/A motor then certainly just run 87, you gain nothing by running more expensive gas.
I would just run it since it wasn't a huge amount and fill it back up at maybe a 1/4 tank or so. I think it will be fine.
2010 2SS
BMR 1" Springs
Koni Orange struts/shocks
1LE rear sway bar
SRP Racing Pedals
Hurst Billet short shifter
Square tire/wheel setup
Elite Engineering Catch Can
Stainless Power longtubes/highflow cats
K&N Typhoon CAI
RPM Motorsports of Garner, NC dyno tune (421 RWHP)
Destructo09 is offline   Reply With Quote
Old 06-22-2015, 01:27 PM   #9
Sandman1969
Sandman1969's Avatar
Drives: 2015 2SS Red Hot Adrenaline
You should be fine especially if she tops it off with some higher octane when she can.
Sounds like the dealer just saw a $ sign pop up when she called in.
Sandman1969 is offline   Reply With Quote
Old 06-22-2015, 01:41 PM   #10
hrpiii
AKA "Beefcake"
hrpiii's Avatar
It is NOT the turbo. I felt better she had been running 89 in it when she added the E85. But yeah, that did lead to another conversation as to "why 89". I think she feels like the Camaro runs good on 93, so her little sonic should get the same treatment. Got to love her.
I agree. She likes to make her own calls and be a big girl. But when they heard a "girl", scared a little and concerned she could have damaged something, they took advantage. If they would have said $100 to drain, I would of been okay with that. But $350 to drain and do nothing else.. please. Apparently they wanted to see "me" today instead of her when I go pick it up. A 230 lb powerlifter rarely gets any lip back from the guy behind the counter.
Old 06-22-2015, 09:03 PM   #11
PalmerGA
PalmerGA's Avatar
Drives: 2013 SIM 1SS/RS L99
That's BS. Just run it through quickly (take a lonnnnnng drive) and top it off a couple of times when it reaches 1/2 a tank. It should be fine.
I didn't know the filler tube configuration would allow you to put E85 in a non-E85 rated vehicle. Hmmm.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
PalmerGA is offline   Reply With Quote
Old 06-22-2015, 10:23 PM   #12
2013 ZL1 #7860
Drives: 2013 ZL1 A6 #7860
it will be fine.
2013 ZL1 #7860 is offline   Reply With Quote
Old 06-23-2015, 05:32 AM   #13
hrpiii
AKA "Beefcake"
hrpiii's Avatar
I never had a vehicle to put E85 in, so I did not know this either. Well, until now.
Old 06-23-2015, 05:32 AM   #14
Chevy_cowboy
Chevy_cowboy's Avatar
Drives: 2011 IOM 2SS/RS M6 Convertible
As others have said, burn it quickly, don't let it sit in there for long... but 4 gallons shouldn't hurt anything.
Chevy_cowboy is offline   Reply With Quote
