06-18-2015, 05:40 PM | #1 |
Drives: black Join Date: Jun 2015
Installing fee
Hi, guys. Could you guys give me some idea about how much to installing lowering springs, exhaust system?
In my local motorsport, they will charge me $1000 for installing h&r lower springs, Magnaflow Catback exhaust system, airaid intake and programmer. Is that too much? Please help me out. Thank you sooooo much Thank you Camaro5.com. |
06-18-2015, 06:49 PM | #2 |
Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
You can install the intake yourself and save some money. That price seems high though.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
06-18-2015, 07:42 PM | #3 |
ZYJ
Drives: 2017 1SS Camaro/6 speed Join Date: Sep 2014
Spring $230
Catback $150 Intake $FREE, less than 30 mins by self, no mechanic experience and knowledge, easy job Programmer, IDK what is that. |
06-18-2015, 09:10 PM | #4 |
Jan
Drives: 2010 Camaro 1LT Red Jewel tintcoat Join Date: May 2010
Don't forget to add the cost of alignment & timing the bushings, etc.
I paid like $450 for my springs installation & alignment. Exhaust depends if it needs to be welded or altered in any way but the above estimate is not far off for that. For sure, you can do the intake yourself.
06-18-2015, 11:27 PM | #5 |
Homeless Life Chose Me
Drives: LS3 (sold 4/21) Join Date: Nov 2014
Just do exhaust by urself. Catbacks are easy. Everything is bolt on no cutting or welding.
Pity a man in familiar places, who yet feels like a stranger.
06-18-2015, 11:35 PM | #6 |
CAI can be easily done by yourself. As was said - no mechanical experience required.
Exhaust/catbacks does require some mech. skills but also not a bid deal. Anyway you can save at least on CAI installation. $1K is too much. Not sure what you meant by "programmer". It that was about dyno tune then the price is fair. |
06-19-2015, 12:17 AM | #7 |
Drives: [COTW 8/3/15] 2010 Camaro SS L99 Join Date: Mar 2015
I'll do all that for $200.00 and a case of beer. The springs can be done by the home mechanic also. Need a spring compressor or rent one...
A Little bit of power. ALL WORK DONE BY ME!
Just added 2021 ZL1 1LE to the Stable! https://www.camaro5.com/forums/showthread.php?t=418273 |
installation |
