Old 06-08-2015, 05:43 PM   #1
judochop87
Drives: Cooper
99 Suburban - intermittent starting issues
I wanted to ask a question about my dad's 99 suburban that won't start, I figured what better place than forum full of GM connoisseurs
Most other car forums have a section to talk about non-camaro related stuff, is it too early to start one mods?
As to the actual question. My dad's 99 5.7 L suburban was stored away all winter. When he tried to turn on last week, he noticed the alternator pulley was seized so we replaced the alternator and belt. He said it wouldn't turn on it first, but he came back a few hours later and it started right up and was running great like she always has, no misfires, no CEL. He tried turning it on the next morning and it would not turn on again, basically it turns on intermittently, but it runs fine when it does. What should we check out next?
judochop87 is offline   Reply With Quote
Old 06-08-2015, 05:59 PM   #2
IOMike
Drives: 2022 F150, 87 Monte Carlo
When it doesn't start, does it crank?
IOMike is offline   Reply With Quote
Old 06-08-2015, 06:09 PM   #3
Capricio
Drives: 2000 WS6
99 suburban owner here (K2500).
Going to assume your alternator is fixed and is no longer the issue.
Are you saying the engine turns over with the starter but never fires? If that is the case:
These things have huge 44 gallon tanks so the fuel pumps tend to give out, especially if you run below half a tank a lot. When you turn the key to the "on" position, just before the the starter kicks in, can you hear the pump? If you can't hear it, try rapping (gently) on the tank with a rubber mallet. On mine, this would sometimes jar a cold connection or something and make the pump turn on. You can also check fuel pressure at the schraeder valve on the fuel rail.
Capricio is offline   Reply With Quote
Old 06-08-2015, 06:19 PM   #4
judochop87
Drives: Cooper
it does crank, even when it doesn't start.
The alternator is fine now, funny you mention the fuel pump as that was my first guess, I will take a look at this this weekend to hear if the pump is working.
Old 06-08-2015, 08:26 PM   #5
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
We do have that ... its just not under the Camaro6 domain. We've got a General Automotive & Other Cars section over on Camaro5 (and in that corner of the site, we've also got subforums for Member Intros, Off-Topic, and Site Related Questions). We just haven't made it all that obvious that Camaro5 & Camaro6 are really the same forum (oh, and Corvette7 ... thats us too).
You can jump between the different sites via a drop-down in the top right corner ("You are browsing <car #>")
Thread has been moved to Camaro5's General Auto section, and has been retitled for better results
-DG
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 06-08-2015, 09:24 PM   #6
wakespeak
wakespeak's Avatar
Drives: 2020 ZL1 1LE
Had to do same with our 2008 Suburban. It worked to get it started so that I could take it to get fixed.
2020 ZL1 1LE [Moroso SC Expansion Tank, otherwise stock]
wakespeak is online now   Reply With Quote
Old 06-08-2015, 09:59 PM   #7
RLHMARINES
1st Civ. Div.
RLHMARINES's Avatar
Drives: Camaroless for now...RIP "Big SexZ"
Fuel pump is your issue, 99.5% sure of it since I have seen this happen to my Tahoe before. Some are noisy when you turn the ignition on and some are not and some will just shut off while driving along with the hard to start issue but I've gone thru 3 fuel pumps on my Tahoe and helped put on a couple on my dads older '98 Silverado. I'm just shy of 300,000 miles on my '01 Tahoe and she is still kicking along just fine with just a 1/2 quart of oil consumption in between oil changes.
Swift....Silent....Deadly
RLHMARINES is offline   Reply With Quote
Old 06-09-2015, 12:01 AM   #8
derklug1
derklug1's Avatar
Drives: 2016 GT350
More than likely the fuel pump, but there is also a ground on the back of the passenger side head that can cause issues. Since it was stored all winter, you may also want to look under the engine compartment fuse box and make sure that Mickey didn't have a dinner party under there.
"Life is hard, it's harder if you're stupid" John Wayne
derklug1 is offline   Reply With Quote
Old 06-09-2015, 12:54 PM   #9
judochop87
Drives: Cooper
thanks everyone. It turned on this morning no problem he says, I think she's trolling us. I'll be checking out the pump on the weekend.
