05-09-2015, 08:48 AM | #1 |
Drives: 2014 2LT RS Coupe (Red Hot) Join Date: Mar 2014
Installed Koni Orange and I now have squeaks
I just had my dealer install Koni Orange front and rear on my V6, along with the Hotchkis 1" lowering springs. Now I have squeaks from the rear and the tech says that it sounds like it is coming from the rear shocks. I am going to drive it for 1 week to see if it goes away. Any thoughts or advice?
05-09-2015, 02:42 PM | #2 |
Drives: '10 RJT-2LT/RS & '10 Buick LaCrosse Join Date: Jul 2009
I have the squeak on my front driver side. It hasn't gone away.
05-10-2015, 08:38 AM | #3 |
Drives: 2017 1SS 6spd Join Date: Jan 2011
Some other owners have reported clearance issues with the Koni Orange strut. See here- http://www.camaro5.com/forums/showthread.php?t=406866
05-10-2015, 09:33 AM | #4 | |
05-10-2015, 11:13 AM | #5 |
Drives: Camaro Justice Join Date: Jun 2007
I doubt the squeak is coming from the tire rubbing on the strut spring perch. Do you have any aftermarket arms, bars or bushings installed?
05-11-2015, 03:30 AM | #6 |
Yes. BMR front bar and sway links. BMR rear sway links and stock bar (waiting for correct replacement bar from BMR). I also now have slow speed klunks in the front.
05-11-2015, 07:22 AM | #7 |
Drives: 2015 2SS/RS 1LE Join Date: Jul 2014
Very interested to hear more info on this... I'm dealing with the same thing (no klunks in the front yet though).
05-11-2015, 07:41 AM | #8 |
05-11-2015, 08:10 AM | #9 |
05-11-2015, 08:35 AM | #10 |
05-11-2015, 10:39 AM | #11 | |
Drives: 2010 CGM Camaro 2SS/LS3 Join Date: Oct 2013
Nothing really to do about the clunking, I think it's a flaw in the OEM strut design, my sway bar endlinks are fine and the OEM struts did it too. It's just more noisy with the Koni oranges. No squeaking though from mine, I have a 1LE bar in the rear though, no aftermarket bars or bushings.
2010 2SS
BMR 1" Springs Koni Orange struts/shocks 1LE rear sway bar SRP Racing Pedals Hurst Billet short shifter Square tire/wheel setup Elite Engineering Catch Can Stainless Power longtubes/highflow cats K&N Typhoon CAI RPM Motorsports of Garner, NC dyno tune (421 RWHP) |
05-11-2015, 11:37 AM | #12 | |
05-11-2015, 11:39 AM | #13 |
That is correct. No reason for any noise with Koni struts.
05-11-2015, 01:14 PM | #14 |
Camaros have always had a front end knocking noise over some bumps at low speed.
Look around on the net and lots of people complain about it. I don't think it's the strut itself, I think it's the way the strut is mounted to the body in the top. It could be the bearing in the rubber isolator is a bit more worn on my car, I probably should have replaced them with the struts.
2010 2SS
