04-19-2015, 12:56 PM | #1 |
Drives: 2017 ZL1, A10, White, sunroof, nav Join Date: Apr 2009
Left front "popping" when turning right under more than light acceleration
anyone experience this and/or know what it is? Spent a day at dealership trying to figure it out...several techs involved....
did the rear diff fluid change, circles, figure 8's 3 times...that wasn't it. Now it is also happening when taking off straight as well...under moderate to heavy acceleration...baffling. |
04-19-2015, 07:09 PM | #2 |
Check lug nuts on that specific wheel
I would also lift the front left corner , and try to move the wheel left/right , bottom in/top out , and see if it sings like when driving , I'm thinking about some link in that wheel is giving up Last edited by oldfriend; 04-20-2015 at 08:13 PM. |
04-19-2015, 07:12 PM | #3 |
Drives: 2010 Camaro 2SS/RS Join Date: Dec 2009
What are the Lag bolts?
94 Firebird Formula (Drowned 08/30/05)
2010 IBM 2SS/RS 6M Arrived 3/25/10. ADM CAI, Borla Type S Cat Back, VMAX Ported TB, LG Short Throw Shifter, 1LE Shocks, Hotchkis Sway Bars, Whiteline Cradle Bushing Inserts, Custom Powdercoated ZL1's ,Michelin Pilot Supersports, Stainless Power Headers, Solo J Pipes, AAC LED Sidemarkers, ZL1 Rockers, SLP Splitter, ADM Stage II Cam,ZL1 Diffuser,Vitesse Throttle Controller. |
04-19-2015, 07:25 PM | #4 |
04-20-2015, 05:34 AM | #5 |
Drives: 2013 Black ZL1 Join Date: Jul 2014
I notice this problem when backing out of my driveway. Never heard it any other time though. Curious to what it might be.
04-20-2015, 06:20 AM | #6 |
Drives: 2013 ZL1 Convertible A6 BRM Join Date: Feb 2015
I had experienced that noise also when backing out my driveway, but now after 2K miles it went away.
2013 ZL1 CONVERTIBLE BRM A6
OHIO |
04-20-2015, 07:29 AM | #7 |
Drives: 2015 ZL1 Black #100 Join Date: Oct 2014
I am experiencing this also but it seems to be coming from the rear. I had mine at the dealership and after checking everything, they wrote it off to drive-train slack. I don't believe this since I have driven manual transmission cars most of my life. I guess I will wait for it to get worse so that they can figure it out.
04-20-2015, 08:42 AM | #8 |
Thanx. Checked the wheel and they are...tight as a tick. Also checked alignment. will double check lugs. Yep...lugs good & tight too.
04-20-2015, 11:58 AM | #9 |
Just got back from my tuner...right away...as soon as he felt it...he knew what it was---- the catalytic converter. He says they just don't last at this power level. Going to have them gutted Thursday.
04-20-2015, 05:09 PM | #10 | |
Drives: ZL1 1LE A10 Join Date: Mar 2015
What power level? Did the tuner give any reason why the cats would make a popping noise? Curious. Thanks!
Current: 2019 ZL1 1LE A10 Mods: MPS4s Tires | Borla Atak | CF Steering Wheel Previous: 2018 ZL1 1LE M6 | 2017 Z06 Z07 M7 | 2017 GS A8 | 2015 ZL1 M6 | 2013 GT500 |
04-20-2015, 06:56 PM | #11 |
Drives: 02 Z06, 95 Trans Am, 2012 ZL1 Join Date: Mar 2012
Sure they can!
Bryan 2018 ZL1 M6
04-20-2015, 09:51 PM | #12 |
Really the cats? Would have never thought that
04-21-2015, 03:47 AM | #13 |
Drives: bmw Join Date: Apr 2015
04-21-2015, 04:59 AM | #14 |
KaBoom1701
Drives: 13' ZL1 Red M6 Join Date: Dec 2012
This is a normal issue.
The brakes seem to lock up after sitting for a while. It's most noticeable after you wash the car or do some "spirited" driving and then let the car sit. The popping noise is the brake pads un-sticking themselves from the rotors.
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats. |
