Old 04-11-2015, 08:14 AM   #1
swallace1
Drives: 2015 Z51
Clicking sound from dash
Does any have a clicking sound coming from dash when the car hits a bump? I do. It is coming from the drivers side dash.
swallace1 is offline
Old 04-16-2015, 08:51 AM   #2
swallace1
Drives: 2015 Z51
Clicking was coming from removal roof
Turns out that the clicking was coming from the area where removal roof meets the windshield. After removing the roof and then replacing clicking has stopped.
Old 04-16-2015, 09:33 AM   #3
BigEastVette
BigEastVette's Avatar
Drives: 2017 Z06 3LZ BLACK ROSE, FORD F250
I have the same issues with my transparent rooftop ever since I got my 2015 Z51. some times it makes noise on the driver side, sometimes the passenger side, it jumps around. I have to unlatch the top, pull it up a little, put it back down nice & tight, then it will stop for a little while, but always comes back in a day or two. I'm thinking about getting some small ( very small) self adhesive rubber stripping to put at each side front corner to see if that stops it. Just have to be careful not to create a potential leak point.
anybody else have this issue ? any other suggestions on a fix ?
thx
BigEastVette is offline
Old 04-16-2015, 10:05 AM   #4
purpleRac3r
purpleRac3r's Avatar
While I haven't experienced any top noises, I have seen an interesting solution on another forum. Slip a small O-ring onto each of the front corner alignment pins. This acts as a small spacer/cusion, eliminating many of the creaks and clicks. The O-rings are 7/16" O.D, 1/4" I.D. and can be found in Lowe's or Home Depot's plumbing departments for a couple bucks for a package of several.
purpleRac3r is offline
Old 04-16-2015, 01:32 PM   #5
BigEastVette
Excellent solution PR3r........... Thanks
Old 04-16-2015, 04:36 PM   #6
swallace1
Drives: 2015 Z51
Thanks Bigeast and Purple.
Old 04-20-2015, 10:13 AM   #7
BigEastVette
stopped by Lowes on Friday to pick up a small package of the rubber "O" rings, popped them on the roof pins, and that baby is now solid, tight, and quiet..........
thanks again PR3r for the tip.............perfect
Old 04-20-2015, 05:07 PM   #8
swallace1
Drives: 2015 Z51
I will try this. I did take off the carbon fiber top and replace with the clear plexiglas. No noise with the plexiglas top. Is this a problem with the 3LT Z51 carbon fiber tops?
Old 04-21-2015, 06:03 AM   #9
purpleRac3r
I suspect its an issue with all tops, just dependent on how the top is installed. Any slight change in alignment of the pins and receivers could allow extra play in the panel causing noise. Even ambient temperature plays a part. It's probably a random phenomenom, and could occur with any top at any time. Those who take the top out more frequently will likely experience it more, as the pin-receiver alignment is changed more frequently.
