Old 01-07-2015, 10:23 PM   #1
Eddie57
Drives: 2015 v6 Camaro
Parallel Parking
I just bought my Camaro a couple weeks a go and men I cant even park the thing straight. Im afraid to attempt parallel parking. Any tips? I haven't tinted my windows yet to avoid reducing visibility until im confident with the car's dimensions. I used to drive a scion tc btw.
Eddie57 is offline   Reply With Quote
Old 01-07-2015, 10:27 PM   #2
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
It will take some getting used to, but you'll get the hang of it. Our cars make it hard to see curbs on a good day, so even in a perfect world their still a PITA
AGP TT kit, 54/57 Forged rotating assembly, Custom grind cam... Dual nozzle meth, ID850's, Livernois dual fuel pumps, ECS BAP, 25% UDP, 3 inch Magnaflow catback with X pipe, Mantic 9000 clutch, DSS 1000hp axles, DSS aluminum driveshaft, ZL1 rear end, solid subframe bushings, HE differential offset bushings, BMR Trailing arm, BMR toe rods, Lingenfelter LNC-2000,SJM Line Lock. 747 whp 714wtq
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 01-07-2015, 10:27 PM   #3
Homer2
Homer2's Avatar
Drives: 50th Anni.. coming home 11/01
Lining it up takes a lil while to get used to... I have 30,000 km on my car since July and its still pleasing when I step out of the car and its parked straight. I should have it down pat by now.
Built Sept 16/2016 - #2681 of 5955. She came home with me 11/01/16. 50th Anni, 2SS, A8, NPP, NGM Rock Guards, Footwell Lighting, Black Bow Ties, Street Warrior Rotors and Pads, Ceramic Pro, 3M PPF, Oracle Ghosted Side Markers, Kooks 2" headers w/hi flow cats. GPI Stage 1 Cam installed at 305,000 kms.
Homer2 is offline   Reply With Quote
Old 01-07-2015, 10:38 PM   #4
CCMADONNA
CCMADONNA's Avatar
Drives: 2014 SW 2SS/RS
DOOOOOD!!!!
i've had it for 6 months and haven't even tried!!!
2014 2SS/RS VERT L99
SUMMIT WHITE
AIRAID CAI
BORLA ATAK CAT-BACK EXHAUST
ELITE ENGINEERING CATCH-CAN
RANGE AFM-DELETE MODULE
HUPER OPTIK 40
CHROME PEDALS
PREMIUM FLOOR MATS
PREMIUM CARGO MAT
DEDICATED 32GB iPHONE HD
[/I][/B][IMG][/IMG]
CCMADONNA is offline   Reply With Quote
Old 01-07-2015, 10:40 PM   #5
Homer2
Homer2's Avatar
Parallel parking would certainly be easier if you tilt the mirror down. just sayin.
Old 01-08-2015, 02:14 AM   #6
ssrs2lt
ssrs2lt's Avatar
Drives: too many
Yeah not easy lots practice.. I've turned mirrors down to see the curb..
Old 01-08-2015, 02:22 AM   #7
christianmotox
christianmotox's Avatar
Drives: ( . )( . )
I'm always afraid to curb my rims.
christianmotox is offline   Reply With Quote
Old 01-08-2015, 03:02 AM   #8
Mark T
American Gold Whisperer
Drives: 2014 White 1LE 2SS/RS/NPP/Rec/Nav
Helpful hints...
Do not parallel park. Instead find some spot wayy in the back. Be sure to take up 3 or 4 spaces. And do not forget the hazard cones around your ride.
Most importantly, stay away from ANY store parking lot. In particular, walmart.
Seriously though. I have yet to 8have the courage to even try to parallel park.
Mark T is offline   Reply With Quote
Old 01-08-2015, 07:31 AM   #9
rocknroll_jeph
rocknroll_jeph's Avatar
Drives: 11 Camaro V6 RS, 03 BMW Z4
I live in a very tight city, I know the difficulty of parking all too well. I am not afraid to admit that I usually have a spotter to help me. If I am alone I will adjust my mirrors to see the passenger side better. I will also get out and look around a few times. I don't think there is anyone here who has had to park in a smaller place than I have! Good luck, be slow, check out the corners and don't worry about what others say about being too careful.
rocknroll_jeph is offline   Reply With Quote
Old 01-08-2015, 09:39 AM   #10
Dizzy82
Dizzy82's Avatar
Practice, practice, practice. Once you get it down it's not difficult.
Old 01-08-2015, 09:42 AM   #11
Cam_Cam
Drives: 2014 Camaro 1SS
Three of my wheels are curb rashed to hell from trying to park on streets. One of the cities I live near has basically 90 degree angled curbs, so if you even bump it... scrrrrrratch. Don't do it if you can avoid it.
Cam_Cam is offline   Reply With Quote
Old 01-08-2015, 09:50 AM   #12
SSJ455
SSJ455's Avatar
I try not to do it whenever possible but if I have to I try to find a place where there are two or more space open and pull in and line it up that way. Hell, I still have issues with backing into a space in a parking lot, though I have gotten better.
What?
Dangerzoooooone.
Old 01-08-2015, 09:55 AM   #13
Cam_Cam
I actually find it easier to back the Camaro in straight than I do pull forward straight. My car will only fit up my driveway and into my garage in reverse (weird angles), so I've gotten used to it I guess. I also back into the same space every day at work, next to a support wall in the parking garage, as close to the wall as I can get... usually about an inch of clearance on the passenger mirror.
Old 01-08-2015, 11:36 AM   #14
mpiersd
mpiersd's Avatar
Drives: ABM #2041
Pracitce, you get used to it.
And tilt the curb side mirror down to see the curb in relation to the side of the car, it helps.
Retired United States Army
Bernadette: 2LT/RS, ABM #2041 of 3903
ZL-1 Springs | CAI | Muffler delete | Magnaflow resonator | LED DRL | RX Catch Can | Mini me
Cortana: 2015 Harley Davidson Road Glide Special
V&H Power Duals Headers & Oversized 450 Raider mufflers | Screamin' Eagle Stage 1 Chisel Extreme intake | Screamin' Eagle Stage 1 programmer
Gretchen: 1994 Ford F350 Crew Cab Long Bed 4x4
51k mile survivor
Own an Aqua Blue Metallic Camaro?
Click here to join us on Facebook and help us in establishing the Aqua Blue Registry to locate all 3903 of these beautiful Camaros!
mpiersd is offline   Reply With Quote
