#1 |
![]() ![]() Drives: Ferrari F430 Spider F1 Azzurro Arge Join Date: Sep 2013
First 2015 Chevy Corvette Z06 Engine Destroyed With Just 891 Miles On The Clock
#2 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 Camaro 2SS/RS Convertible and: Join Date: May 2014
"Breaking" in the engine, boys...
Currently in my Garage: 2011 Camaro 2SS/RS Convertible | 1980 Corvette Stingray | 1981 Firebird | 1968 El Camino | 2007 Crown Vic Police Interceptor | 2001 Silverado | 2001 Blazer | 1965 Chevy C-10 | 2007 Harley Softail Custom | 2013 MX-5 in Copper Red Mica | 2000 Corvette Convertible | 2010 Corvette Grand Sport | 2006 Audi A3 Turbo | 2008 BMW 328i ![]() |
#3 |
![]() Drives: Cadillac on four flats Join Date: Mar 2012
I'd rather the engine "break" withing the first 1000 miles than breaking down when the warranty is out or years later. There is a reason it is called the "Break...in...period".
#4 |
Dam!!! That stinks!
Sit Back and Enjoy The Ride!!
#5 |
Anabolic Connoisseur
Drives: Sold - Blown Camaro 2SS/RS LS3 Join Date: Sep 2010
Ouch
#6 |
![]() ![]() ![]() Drives: 2016 Nightfall Gray Metallic SS Join Date: Dec 2013
Chalk that one up for the "not too good file". I'm sure GM will get these issues worked out.....
2016 Nightfall Gray Camaro SS |
#7 |
![]() Drives: 2010 camaro 2SS Join Date: Mar 2012
Ehhh, shit happens.
www.lashwaymotorsports.com
2012 L99, whipple, Roto-Fab, Stainless Power headers, ZL1 fuel pump, cat delete. |
#8 |
![]() Drives: Slow Join Date: Apr 2010
I don't know if anyone is following this story over on corvetteforum, but the drama is off the charts. Here's a link: http://www.corvetteforum.com/forums/...-is-blown.html
Anyway, whatever caused the failure, whether it was a manufacturer defect or owner abuse, I don't know. But according to the OP, there are four more engine failures that he knows of: http://www.corvetteforum.com/forums/...post1588619937 So this may be more than just an isolated indecent. |
#9 |
![]() Drives: 2 sad communter cars. Join Date: Nov 2014
What sucks is it's no longer a numbers matching car. Not sure, but for a Z06 I think that might matter.
#10 |
Too much is never enough!
Drives: AGP TT SS [COTW] 4/20/15 Join Date: Feb 2014
I wouldn't say this had anything to do with operator error, or improper break in. Unless GM's fail-safe's for the ZO6 are different from the rest of their cars. Even if he shifted down a gear, or over reved the car he would still hit a rev limiter. I could be totally wrong about the saftey systems on a Vett but thats the way it is on our cars, unless you tune it out.
AGP TT kit, 54/57 Forged rotating assembly, Custom grind cam... Dual nozzle meth, ID850's, Livernois dual fuel pumps, ECS BAP, 25% UDP, 3 inch Magnaflow catback with X pipe, Mantic 9000 clutch, DSS 1000hp axles, DSS aluminum driveshaft, ZL1 rear end, solid subframe bushings, HE differential offset bushings, BMR Trailing arm, BMR toe rods, Lingenfelter LNC-2000,SJM Line Lock. 747 whp 714wtq
Build thread http://www.camaro5.com/forums/showth...55#post8107855 |
#11 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2015 SS 1LE Red Hot, 1970 Chevelle Join Date: Apr 2012
#12 | |
I'm not about to try again but when I first bought my car I missed 4th and hit 3rd and it cut out.
Build thread http://www.camaro5.com/forums/showth...55#post8107855 Last edited by 1KillerSS; 01-02-2015 at 11:08 PM. Reason: spelling |
#13 | |
36.58625, -121.7568
#14 |
Well if you had hit second instead of fourth at a high enough speed it would have been a different story. The inertia of the vehicle will cause the motor to over-rev, no electronics will save you in that scenario.
