Old 12-25-2014, 09:28 PM   #1
BLACKC7
Drives: 2014 C7
Wide tires on my C7
I just installed some Forgestar F14 on a set of 285/30/19 Michelin Pilot Super Sport Zp on the front and 335/25/20 on the rear. The tires stick out about 3/4" past the front and rear fenders. I think it give the car an aggressive stance. What do you guys think?
BLACKC7 is offline
Old 12-25-2014, 10:33 PM   #2
monicatomokc
monicatomokc's Avatar
Drives: 2014 Corvette 2021 Tahoe Z71
Yes. Are those rims actually for a Z06?
monicatomokc is offline
Old 12-25-2014, 10:45 PM   #3
BLACKC7
Drives: 2014 C7
Yes the tires are the same size as the new Z06.
BLACKC7 is offline
Old 12-26-2014, 07:51 AM   #4
binko
Drives: Honda Accord
They look great. Be sure to keep an eye out for any possible erosion of paint where road sand and stone chips will fly up and etch the side of the car behind both the front and rear tires.
binko is offline
Old 12-26-2014, 08:09 AM   #5
purpleRac3r
purpleRac3r's Avatar
As binko says, watch for rock chip damage, especially along the rockers in front of the rear wheels. That area is prone to chips with the stock size tires - those steamrollers of yours will just make it a lot worse! Consider Xpel in those areas, and maybe the factory accessory splash guards. Apsis also makes a nice flare kind of like the C6 Z06 had that works with the Stingray. Any of these will be far less expensive tyan a repaint, and will look better than a bunch of little white specs at deep paint chips!
purpleRac3r is offline
Old 12-27-2014, 12:17 AM   #6
REVVIC
Drives: 2014 Z51 Velocity Yellow
I'm certain you'll get tire and fender rub/contact on hard cornering for the front. For the rear, at highway speeds you may also get contact when encountering long dips on the road surface. Especially, if two people are in the car along with luggage. I put 3/4" spacers on the rear with stock Stingray wheels and tires. The tires didn't protrude as much as yours and I got fender contact on the sidewalls after cresting hills on the interstate at about 70 mph. BUT NOTE...my Vette has been lowered 3/4" front and rear. With your protrusions, lowering might not be a good idea.
REVVIC is offline
Old 12-27-2014, 12:49 PM   #7
2corvette2
2corvette2's Avatar
Drives: 2014 Coupe Laguna Blue Tintcoat
Not my cup of tea, but my opinion does not count, only yours does.
2corvette2 is offline
Old 12-28-2014, 01:09 PM   #8
mowilson329
mowilson329's Avatar
Drives: 2014 Stingray 1LT/Z51
I've never liked the look of tires protruding outside the fender wells.......but as others have said, as long as YOU like it, that's what matters.
I think I've seen you around.......are you from the Jax area? The ALL BLACK looks great!
Cliff
mowilson329 is offline
Old 01-01-2015, 12:54 PM   #9
BLACKC7
Drives: 2014 C7
So far no fender rub! Also I just added the front fender extension which you see on the new Z06.
Yes I'm in the Jax and thanks.
BLACKC7 is offline
Old 01-01-2015, 09:40 PM   #10
m3incorp
Drives: Buying 2014 Stingray
Let's see a full side and rear pic with the fender extenders.
m3incorp is offline
Old 01-02-2015, 07:57 PM   #11
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
No thanks, looks aftermarket....
Glen e is offline
Old 01-03-2015, 07:44 PM   #12
Tony M
Tony M's Avatar
Drives: 2014 NRB LT1 Z51 C-7
BLACKC7 where did you purchase the fender extensions ? The blackout looks great on your C7 . Enjoy..............
Tony M is offline
Old 01-13-2015, 04:07 PM   #13
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Take a great aerodynamically engineered 80k stingray and put oversize tires.....ok?
Mods:
KaBoom1701 is offline
Old 01-13-2015, 09:10 PM   #14
SR-71
SR-71's Avatar
Drives: 2015 Z51 Coupe 2LT Shark/red
Not for me, but enjoy!
SR-71 is offline
