Old 12-23-2014, 01:01 PM   #1
chuckawesome
Drives: 2014 Corvette Stingray
Need Help
Is there a way to save or "set" which exhaust mode your C7 starts up at? i thought mine started at whichever i last used but for some reason it keeps starting up on "touring" mode now and i want to change it so it just stays on "track" mode.
Any help would be appreciated.
Thanks
chuckawesome is offline
Old 12-23-2014, 01:13 PM   #2
JDMAC
Drives: 2015 Laguna Blue C7
What I have read on the exhaust system is that touring is the default mode and will revert to that mode anytime car is shut down. I don't know for sure but I do not think this setting can be changed.
JDMAC is offline
Old 12-23-2014, 02:11 PM   #3
chuckawesome
ok thanks, i can't find anything that says different either. shit. sounds so much better when you fire it up in track mode, especially with some mods.
Old 12-23-2014, 02:28 PM   #4
NC C7
NC C7's Avatar
Drives: 2014 CRT C7
I nearly always drive in S mode and mine doesn't change at all unless I turn the knob. It's in S on start up and shut down. Sorry, but I don't know how to keep your's in T mode.
NC C7 is offline
Old 12-23-2014, 04:57 PM   #5
regguy1
regguy1's Avatar
Drives: 2014 Corvette Coupe
Go to settings menu and you can set it to always be open
regguy1 is offline
Old 12-23-2014, 10:01 PM   #6
noname
Drives: 3LT Z51
The C7 and Z06 can both be controlled through the infotainment center.
http://www.corvette7.com/forums/showthread.php?t=385835
Turn sound management to off and the exhaust mode will always be open regardless of the driver mode
noname is offline
Old 12-24-2014, 06:55 AM   #7
chuckawesome
ok thanks.
