#1 |
![]() Drives: Ford Edge,Smart, BMW,2014 Stingray Join Date: Jan 2014
Shift limiter
This probably has been discussed before. The owners manual does not
really explain the 1st to 4th skip shift. What is the real purpose? My feeling is, if one an afford a C7, how important is fuel economy? Dealer offers no good explaination other than run the revs up to cancel it out Thanks for your thoughts |
#2 |
![]() Drives: 2015 C7, 2002 Pontiac Formula Join Date: Sep 2014
I believe that the skip shift is indeed for fuel economy, but not the way you are thinking. By using the skip shift I think that Chevrolet just slid in under the wire on avoiding the gas guzzling tax. Could be wrong, but I thought I read that somewhere recently. My Formula has the same thing, and disabling it was the first mod I put in. Will do the same when I get my C7 next summer.
#3 |
WHEELIEFEST 22 ~ 8/14/21
Drives: 18 HW, 16 Vette, 09 G8 GT, 02 Formu Join Date: Jan 2011
I too understand that it helps GM avoid the gas guzzler tax on its manual shift performance cars. All my new V8 6 speeds have had skip shift(02 Formula, 04 GTO, 06 GTO, 10 2SS Camaro, & 14 Corvette) and all avoided the guzzler tax. Automatic GTO's all had the GG tax and automatic V8 Camaro's have 26 less HP with added AFM to avoid it.
24 Panther 3LT RS Camaro 6SPD
21 Cadillac CT5 Sport 18 Hot Wheels 2SS convertible 16 Torch Red Corvette 2LT 7SPD 10 Inferno Orange Camaro 2SS 426 HP LS3 "MAIDEN" (TOTALED!) 09 Stryker Blue G8 GT w/sport/prem/sunroof 02 Firebird Formula LS1 HURST 6SPD(1st new car) |
#4 | ||||
Truth Enforcer
Drives: anything I can get my hands on Join Date: Sep 2006
* you're in 1st gear * you're at 35% throttle or less * you're between 15 and 21 mph * engine coolant temperature is greater than 171 F (77 C) instead of rev, clutch, rev, clutch, rev, clutch to get from 1st to 4th gear, it forces you to go straight from 1st to 4th in an effort to get better fuel economy in low speed/city driving. its supposed to be less invasive with the C7 over prior vehicles, but still there. there are numerous options for disabling it as well. including our vendors http://www.apex-speed.com/apex-motor...ator-8001.html
A group as a whole tends to be smarter than the smartest person in that group until one jackass convinces everyone otherwise. Quote:
