10-30-2014, 06:52 AM | #1 |
Drives: 13 Camaro ZL1 Join Date: Apr 2014
anyone with problems with their New solid isolator Supercharger
Seeing if any other ZL1 owners out there are experiencing what I am. Bought a leftover 13 A6 ZL1 with 38 miles on her.when I test drove the car with 38 miles there was a noise coming from under hood. I didn't really worry about it until I found out about the isolator problems and the SC tech bulletin. The noise I heard since day one is the common isolator noise. So at 3600 miles I had my dealer replace SC under bulletin. They did a great job on replacing the SC and had no complaints when I picked her up. I am Very OCD on this car and who works on it. I was a mechanic for years and know all about dealers. For roughly 500 miles no noises and car performed great. Until recently seems like the isolator noise is back. Sounds exactly the same as before. It's been making the noise for a couple hundred miles now. I haven't talked to dealer about it but will take her back in soon.
I am wanting to see if anyone else has a noise on their new Supercharger??? Thank You |
10-30-2014, 07:58 AM | #2 |
Drives: 02 Z06, 95 Trans Am, 2012 ZL1 Join Date: Mar 2012
The same rattle at idle? If so I'd wonder if they replaced it with the same old design instead of the new one. May have been some old stock still on the shelf somewhere. To test it pull the belt off the SC and rotate the SC pulley back and forth rapidly. If you have a little slack and can make it knock doing this you have the old design.
Bryan 2018 ZL1 M6
10-30-2014, 08:13 AM | #3 |
Jetcop20
Drives: '13 ZL1 A6 Join Date: Jun 2012
what noise
4100 miles and not a hint of the DREADED SC noise I am really suprised that yours with 38 miles had it...then they change it out with the same type and again 500 miles and poof NOISE....[ATTACH][/ATTACH]
10-30-2014, 09:40 AM | #4 |
Drives: 2013 Camaro ZL1 A6 Join Date: May 2013
47k miles and no noise on my 13.
10-30-2014, 10:20 AM | #5 |
Keep in mind that the same TSB that described the process for replacing the SC due to the dreaded marble rattle and extended the warranty to 120k miles, also described the 'flutter' that will still be audible with the new SC at certain rpm's and load levels.
10-30-2014, 11:14 AM | #6 | |
I'm at 12k and still no noise.
10-30-2014, 12:18 PM | #7 |
10-30-2014, 12:51 PM | #8 |
Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
Have a tech check out the noise with a stethoscope. Maybe an idler pulley knocking? Also just to make sure, see if the supercharger part number put on is the one in the bulletin.
10-30-2014, 03:48 PM | #9 |
EOD
Drives: 2015 ZL1 Join Date: Jan 2011
I had mine replaced about a month ago and it's become more noisy than the original. And it's not in 2 or 3 gear low rpm under load as the flutter bulletin describes. Mine is noisy at idle and unlike the original I can hear it inside the cabin. My dealer reported this to GM and gave me a case number. So far the dealer is being told that GM is aware that the new ones are making noise too and have no current direction/fix. I'll be checking again at the end of the week since I've been waiting for over 3 weeks for an answer from GM.
Is there a different part # for the newer supercharger? I'd like to check that out. |
10-30-2014, 11:27 PM | #10 | |
Drives: 2013 Camaro ZL1 Join Date: Oct 2012
10-31-2014, 12:35 PM | #11 |
Drives: 2013 ZL1 #505 Join Date: Nov 2012
I had my SC replaced about 3 months ago and no noise here, although another buddy of mine had same procedure done and his SC is rattling once again
11-01-2014, 06:52 PM | #12 |
Drives: 2013 ZL1 Ashen Gray Join Date: Oct 2013
I replaced my own isolator with a LPE and don't have any noise/flutter,I think some of these noises are random.
I don't have to know everything,I just need to know,what I need to know,when I need to know it!
MODS, a lot of money,a lot of parts,a lot of time,a lot of patience. 754 RWHP 747 RWTQ 93 Octane http://www.camaro5.com/forums/showthread.php?t=347243 |
11-01-2014, 11:38 PM | #13 |
Drives: 18 ZL1 A10 & 18 2500HD Duramax Join Date: Oct 2012
34,000 miles with Metco solid isolator and no noise
Procharged 2018 ZL1 A10
2018 2500HD Duramax |
11-02-2014, 02:45 AM | #14 |
Drives: 2013 CRT ZL1 Join Date: Sep 2012
I had mine replaced about 3 months ago as well and checked it again after reading this thread. Put my ear right too the supercharger cover while running and car completely warmed up. No marbling, fluttering, or rattling...
Manual... Sent from my SM-N900V using Tapatalk |
