Go Back   Chevrolet Corvette Stingray C7 Forum > Technical Forums > Cosmetic Modifications
Old 09-08-2014, 03:14 PM   #1
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
Carbon flash fish released
Patrick tells me they are in stock today at $16.50 each - genuine GM part
patrick@gmpartshouse.com
Old 09-11-2014, 11:36 AM   #2
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
here's the fish received today from Patrick - excellent quality - perfect gloss from GM. Going on a friend's car this weekend: ignore specks on cam lens, they are perfect...
Old 09-11-2014, 12:58 PM   #3
EDK53
Drives: 2014 Corvette Stingray 2LT Z51
Here is my dumb question of the day. How do you remover the originals and how do you install these?
EDK53 is offline   Reply With Quote
Old 09-11-2014, 01:27 PM   #4
asptroopa1
asptroopa1
asptroopa1's Avatar
I'm sure Glen E has a real good way- but I use dental floss......pull it behind it
asptroopa1 is offline   Reply With Quote
Old 09-11-2014, 01:46 PM   #5
EDK53
So it's just adhesive?
Old 09-11-2014, 03:39 PM   #6
mowilson329
mowilson329's Avatar
Drives: 2014 Stingray 1LT/Z51
I use the same method as asptroopa1........use dental floss or a thin twine of some sort and use a "sawing" motion back and forth and it comes right off. Use a little Goo Gone to get any remaining residue off and you are good to go.
Make sure that you "mark" somehow where the replacement goes so that you get it aligned properly
Cliff
mowilson329 is offline   Reply With Quote
Old 09-11-2014, 04:24 PM   #7
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
Any way that works is a good way, I use fishing braid as it holds up better than floss, and cuts like crazy- even your fingers- be careful....the trick with any thing you use is don't get impatient, let the goo gone do it's work, use an eye dropper and irrigate the adhesive every 15 min for an hour, the badge literally falls off.
Old 09-11-2014, 05:17 PM   #8
EDK53
Thank you!
Old 09-11-2014, 05:18 PM   #9
EDK53
RT. Thanks!!
