Old 09-01-2014, 12:00 AM   #1
richard200593
richard200593's Avatar
Drives: 2012 45th Anniversary RS
Someone that knows natural gas plumbing
So I have been helping my father in law build an outdoor island with a built in BBQ and we just finished running the natural gas lines for it. Did an air pressure test from the line going to the house to the last solid pipe before the bendable pipe going into the BBQ and it help 15psi with no leak at all. Connected the bendable natural gas line to the BBQ and tested again and we have a 1/2 a psi per 15 min leak (only let it drop to 14 did not continue to see how low it will drop). Brand new hose brand BBQ all control knobs are off and checked for leaks on the hose could not find any... We're stumped.
FYI he is the brains and knows all the technical terms I'm just the Braun.
*Performance:
mrt v2.0 exhaust/CAI Intake
*Cosmetic:
Zl1 factory Reproduction wheels
Bmr 1.2/1.4 springs/Oracle plasma drl lights, footwell ambient lighting, 45th Gobo lights
*Audio:
Memphis pr600 amp/Fosgate 12" t0 sub/******** stealth box
richard200593 is offline   Reply With Quote
Old 09-01-2014, 12:05 AM   #2
SS Blinder
SS Blinder's Avatar
Drives: 2011 SS (Sparrow Spearer???)
how you check for less? i've used soapy water and spray entire line down. then just look for bubbles. if you've done that, see if the BBQ by trying to light it off like if you were going to start grilling.
Black magic woman, don't turn your back on me baby!
SS Blinder is offline   Reply With Quote
Old 09-01-2014, 12:07 AM   #3
SS Blinder
SS Blinder's Avatar
damn my english is not working today. meant leaks and try to fire up the Bbq as if you were going to grill with the gas off
Old 09-01-2014, 12:12 AM   #4
its a syn
B.O.D. 02/16/10
its a syn's Avatar
Drives: 2010 SGM Sp. Edition 2017 RS Conver
Soapy water. Big bubbles=Big leak, Small bubbles take some time to develop to show small leak. 10 minutes will show anything. What connections are you using? May have cross threaded something. Split flares can be the cause also.
its a syn is offline   Reply With Quote
Old 09-01-2014, 12:14 AM   #5
richard200593
We did a quick check with soapy water was getting dark so we will do a more extensive one tomorrow but there's only two possible connections and we triple checked how tight those were. We turned one of the burners on on the grill and it definitely had a lot of pressure like it is supposed to. I'm wondering if it has something to do with the internal pressure regulator on the grill.
*Performance:
*Cosmetic:
*Audio:
Old 09-01-2014, 12:18 AM   #6
richard200593
Not sure what you mean by type of connections. I know it's metal has pipe and the flex hose is metal with plastic coating. We actually had originally tested the whole line, saw it had dropped disconnected flex pipe and BBQ and tested again with no pressure drop than re-connected the flex hose with the goop (I know that's not even close to it's real term) and it threaded pretty easily so I don't imagine it's cross threaded but tomorrow will definitely double check. Appreciate all the advice folks
*Performance:
*Cosmetic:
*Audio:
Old 09-01-2014, 12:31 PM   #7
Cuejo
Cuejo's Avatar
Drives: 2013 2ss/rs
The gas valves on the BBQ will not hold up to 15psi
Gas pressure is 7" water column, that's less than 1/2 psi
Hook the gas up and soap test for leaks.
Hopefully you didn't blow the regulator on the BBQ.
Gas should be left for professionals....
Cuejo is offline   Reply With Quote
Old 09-01-2014, 07:24 PM   #8
richard200593
I appreciate the help but I disagree that gas needs to be left to the professionals. We are not getting anywhere near the existing gas line until we have quadrupole tested everything after that to make sure we have zero leaks and zero issues than will have an inspector come take a look before the final connection is made.
Did the soap and water test and found zero leaks and tested the line at 2 psi and have had no leak in 45 mins. Think we're in great shape next is call the pro to take a look and give us the go!
*Performance:
*Cosmetic:
*Audio:
Old 09-01-2014, 07:27 PM   #9
Cuejo
Cuejo's Avatar
Drives: 2013 2ss/rs
I'm glad you don't seem to have a leak.
However, if you're house blows up because you worked on your gas line without the proper training, your insurance company as well as all your neighbors that had houses that also blew up, will all disagree that homeowners should be working on gas lines.
Old 09-01-2014, 07:40 PM   #10
Midlife conVert
Drives: Black 2LT Convertible
I totally agree the someone of a good knowledge of piping can do gas lines. You need a shut off right at the grill regulator. I have seen few grills that can 100% hole up to any gas pressure over time. It is in every manual that I have seen to turn off the gas after finished with the grill.
Check out Alabama Camaros on Facebook! https://www.facebook.com/groups/173934389435353/
Midlife conVert is offline   Reply With Quote
