Old 08-11-2014, 04:11 PM   #1
Gabbott
Gabbott's Avatar
Drives: 2014 Crystal Red C7 Convertible *
Center Dash Vent Rattles
Anyone else have a vibration/rattle coming from the center, dash air vent?
The plastic louvers that direct the airflow are rattling.
This happens only when driving on roads that aren't smooth.
The sound appears to come from the dash, but if I stuff a few fingers into the plastic vent louvers, the noise quits.
The car is only a month old. Anyone else experience this? And if so, anyone found a cure, other than stuffing a sponge or similar item into the vent? And, staying off rough roads!
Gabbott is offline
Old 08-11-2014, 04:59 PM   #2
marc0779
Drives: 2014 stingray z51,2015 zo6
I have the same problem if you turn it to the rt or left it tightens up center position is loose on mine, luck thats my only rattle.
marc0779 is offline
Old 08-11-2014, 05:09 PM   #3
Gabbott
Gabbott's Avatar
marc0779;
I was hoping that others will have this same issue, as that means more of us will be working on a fix?
Maybe someone will even tell us that the factory has come up with a cure?
I've tried pressing it either to the left or right to eliminate the rattle, but no success so far. Maybe a drop or two of super glue in the right place????
Gabbott is offline
Old 08-12-2014, 12:58 AM   #4
Rohey
Drives: 2014 C7 in Cyber Gray
yeah I have the same rattle. tried to locate but no luck so forced me to take off the roof and enjoy the sun or turn up the tunes . either way the rattle does not seem to bother me
Rohey is offline
Old 08-14-2014, 08:51 PM   #5
5150 BRD
5150 BRD's Avatar
Drives: 2014 Z51 Corvette Stingray
I have the same issue on occasion. Seems to come from the center vent. I'll try the "left/right" move.
Brian
Arctic White/Adrenaline Red
5150 BRD is offline
Old 08-16-2014, 05:17 PM   #6
chazysoccer11
chazysoccer11's Avatar
Drives: 2011 Chevrolet Camaro SS/RS
I have the same rattle. The driver's door also rattles if the bass is turned up. I remedy the door rattle my putting pressure on the door panel with my elbow.
2011 2SS/RS RJT M6.
PCTXHN Ordered 8/4/2010 Built 9/28/2010
chazysoccer11 is offline
Old 08-18-2014, 12:06 AM   #7
REVVIC
Drives: 2014 Z51 Velocity Yellow
I've had the same rattle. Moving it left or right has been the only remedy..... for a while.
REVVIC is offline
Old 08-21-2014, 12:52 PM   #8
Gabbott
Gabbott's Avatar
Update:
I had another opportunity to experience the rattle. On my car, it appears to be the bottom/lower horizontal, black plastic louver that is vibrating. By placing a finger on it, the vibration noise stops.
The dealer checked their computer, and apparently no one else has taken their C7 back in for this matter? They want me to bring mine in, so they can examine the vent. Which I'll do pretty soon, and report back here.
Gabbott is offline
Old 08-21-2014, 01:03 PM   #9
NC C7
NC C7's Avatar
Drives: 2014 CRT C7
My car is three weeks old and it does the same thing but not every time out , just occasionally. Lucky for me I've lost some hearing in my left ear so I don't notice the rattle as much as the rest of you guys.
NC C7 is offline
Old 08-25-2014, 12:15 PM   #10
kalimus
kalimus's Avatar
Drives: '14 Z51 3LT Stingray and '13 Cruze
I have the same rattle. That little speaker grill thing on the dash. Pisses me off. I've been meaning to call the dealer, but I've been lazy.
"We have a mental health problem disguised as a gun problem, and a tyranny problem disguised as a security problem."
"What is a moderate interpretation of the text? Halfway between what it really means and what you'd like it to mean?" -Antonin Scalia
kalimus is offline
Old 08-30-2014, 05:04 AM   #11
Boomah
Boomah's Avatar
Drives: C5 Z06
Same here, started about half way across the US during my "delivery" drive. Wife noticed it was coming from said vent, moved it around a good bit which appears to have fixed it. No further issues for the remainder of the trip (Kansas to LA). Will see if it's an issue when I get back home to Hawaii, so jones'n to drive that car again!!!
Boomah
Boomah is offline
Old 10-16-2014, 01:06 PM   #12
Gabbott
Gabbott's Avatar
There appears to be a fix for this?
A friend of mine recently has his center A/C vent replaced (on his C7) at the dealer, and he says that it no longer rattles. His information is below:
My repair order states "Replace Right Center IP Air Outlet Adjust Rattles - No Abnormal Noise After Repair" The outlet P/N is 20989582.
My service advisor has ordered me a replacement vent/outlet. I will have it installed soon.
Gabbott is offline
Old 10-16-2014, 11:41 PM   #13
REVVIC
Gabbott, I'll be taking mine in for a defective infotainment screen and will request new vents.
REVVIC is offline
Old 10-29-2014, 12:29 PM   #14
Gabbott
Gabbott's Avatar
Update: It appears that the General has a fix for this issue:
I took my C7 into the dealer last week for the center-dash vent rattle. They replaced the vent, "Replaced Left Center Vent" (part # 20989582). Took them about three hours.
I've driven the car twice now, and no more rattle noise.
You probably will not get a call from your service advisor about this. Call and make an appointment, and have the vent replaced while its under warranty.
Gabbott is offline
