Go Back   Chevrolet Corvette Stingray C7 Forum > Technical Forums > Wheels | Tires | Suspension | Brakes
Old 07-30-2014, 03:14 AM   #1
H2OStingray
H2OStingray's Avatar
Drives: 2014 Red/Red Z51 3LT
Will a 315/35-20 tire rub on the fender?
I am getting new wheels and one company sells a 315/30-20 tire which should not rub but it is more of a track tire. The other tire I like is a 315/35-20 and should be a better overall tire but I want to make sure it will not rub. My car is my daily driver so I want it to be as streetable as possible.
Also if I get the 315/35-20 will have to run a 265/40/19 in front to level it out and will that tire have clearance?
Running a 19x9 front and a 20x11 rear
Thanks in advance for any help
H2OStingray is offline
Old 08-10-2014, 09:32 PM   #2
m3incorp
Drives: Buying 2014 Stingray
You didn't state the manufacturer of the tires that you want. A 315 from one manufacturer may very well be wider or narrower than that from another; wheel offset makes a big difference also.
m3incorp is offline
Old 09-12-2014, 10:52 AM   #3
m3incorp
Hi, which size did you decide to go with?
m3incorp is offline
