Old 06-21-2014, 02:25 PM   #1
XxShhiKnowxX
Drives: 2LT Z51, Black on Black
V4 mode
This may be a silly question but....how can you tell if you are in v4 or v8 modes?
XxShhiKnowxX is offline
Old 06-21-2014, 03:05 PM   #2
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
Go to the fuel range display, it will bounce from v4 vs v8....be aware it seems seamless if you don't watch it chsnge, once you watch it, you'll think you have a huge problem with it changing.....lol
Glen e is offline
Old 06-21-2014, 03:48 PM   #3
XxShhiKnowxX
Perfect I'm gonna check it out
Old 06-21-2014, 10:06 PM   #4
buckeye4
buckeye4's Avatar
Drives: Cyber Gray Metallic 1LT Coupe
Agree, cannot tell the transition.
buckeye4 is offline
Old 06-24-2014, 06:59 PM   #5
Schlok
Schlok's Avatar
Drives: 2015 Z/28 #397 2022 ZL1 #1799
Interesting, because I can totally tell in my car. I can feel the shudder in the drivetrain when it switches. I have a 7 speed, you all?
Schlok is offline
Old 06-25-2014, 08:44 AM   #6
Stingray
just can't get enough
Stingray's Avatar
My take is that if you consciously look for it, you'll feel it especially if you firmly grasp the shifter on a M7... but still a minor transition to/from though IMO so hardly noticeable.
Stingray is offline
Old 06-25-2014, 10:20 AM   #7
purpleRac3r
purpleRac3r's Avatar
I too have the manual and can feel the transition. Sometimes under light engine load conditions I don't really notice, at other times its quite evident by a momentary shudder in the car. This is usually when at low rpms (around 1000) and when load conditions change, such as going from level to sloped terrain.
I can easily understand how the auto trans will be much smoother, since the engine is isolated from the rest of the drive line at the torque converter. Us manual owners will always feel more as the clutch "direct connects" the engine & drive line.
purpleRac3r is offline
Old 06-30-2014, 01:03 PM   #8
terry.wilks
Drives: velocity yellow, Black on Black 2lt
I have a manual and have to really concentrate to feel the transition under any driving conditions
terry.wilks is offline
Old 06-30-2014, 08:54 PM   #9
SilverRay
SilverRay's Avatar
Drives: 2014 Silver C7 Z51 Stingray
There is one other way to tell when you go into V4, and just maybe this is what some of you are feeling or hearing, if you have your engine sound management set to off, it keep your exhaust valves open, however no matter what mode you are in (i.e. Sport or Track) when the stingray goes into V4 the exhaust valves will close, you can hear the valves close. Sounds kind of like a vacuum closing, the stingray goes quiet, tap the gas valves open and you’re back in V8 and the exhaust sound good again. GM defaulted to close the exhaust valves because they didn’t like the sound of the exhaust open in V4 mode. Also it will go into V4 whenever there is no load on the car no matter what drive mode you have selected. And of course if you’re in tour or a lesser aggressive setting with the engine sound management turned on the exhaust valves stay closed. You can rest assured that if you’re cruising on fairly level ground you’re in V4.
SilverRay is offline
Old 06-30-2014, 10:33 PM   #10
gprscuba
Drives: 2012 2LT RS
I have a 2011 Silverado and it is very noticeable and irritating every time it drops to V4. I actually took it back to the dealership to have it looked at and of course I got the typical "this is normal" answer. I'm praying I don't have the same issues with the C7 when I take delivery.
gprscuba is offline
Old 07-01-2014, 06:49 AM   #11
Stingray
Stingray's Avatar
Originally Posted by SilverRay View Post
... Also it will go into V4 whenever there is no load on the car no matter what drive mode you have selected. And of course if you’re in tour or a lesser aggressive setting with the engine sound management turned on the exhaust valves stay closed. You can rest assured that if you’re cruising on fairly level ground you’re in V4.
This is true for the Automatic C7's... the Manual goes to/from V4 under Eco mode only. All other 4 modes, it always stays in V8.
The C7's AFM iis much more transparent. My DD is an automatic 2012 Camaro SS with the L99 and the AFM mode in it is quite annoying... solved it back in March 2013 with the Range device so it's always in V8 mode when plugged in the OBD.
Stingray is offline
Old 07-04-2014, 10:15 AM   #12
chazysoccer11
chazysoccer11's Avatar
Drives: 2011 Chevrolet Camaro SS/RS
That and if you have NPP, you can audibly hear the change from V4 to V8.
2011 2SS/RS RJT M6.
PCTXHN Ordered 8/4/2010 Built 9/28/2010
chazysoccer11 is offline
