Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Garage / Tools Discussions
Old 06-06-2014, 10:45 AM   #1
maddoggyusa
maddoggyusa's Avatar
Drives: 2013 Camaro Dusk 2SS/6
ramp mods for changing oil?
I have a set of ramps I normally use to change oil. For low front ends, I can often use wood to help but wasn't even close with my front splitter.
was curious what everybody is using when changing oil. I really don't want to jack up the car each time. any good ideas so I don't have to buy another set of low profile ramps? can I add some sort of low profile extension to my current ramps? any picts?
maddoggyusa is offline   Reply With Quote
Old 06-06-2014, 11:03 AM   #2
Cheetoh
Drives: 2011 Callaway SC572, 2000 Firehawk
Race Ramps, Nothing beats the for a lowered car!!
http://www.raceramps.com/
2011 Callaway Camaro, 572 H.P
Cheetoh is offline   Reply With Quote
Old 06-06-2014, 11:13 AM   #3
tmcclint
tmcclint's Avatar
Drives: 2014 AGM 2SS/RS 1LE
The race ramps are like $300. Rhino ramps are like $60 for not much less plastic. Why is it that some small company doesn't make low profile ramps in the $75 range? The liability can't be much more for low profile versus the regular ones can it? I'm in the same boat as the OP so I'd like to know if there is any other solution beside race ramps. I'm sure race ramps are great, but they just seem a bit high for what they are.
2014 2SS RS 1LE
tmcclint is offline   Reply With Quote
Old 06-06-2014, 11:39 AM   #4
maddoggyusa
yea, $300 isn't a good option. ugh.
after some researching... I think I'll be buying these extensions tomorrow at Carquest. my current ramps look exactly like the black ramps (except mine are yellow). Although still not sure they're low enough... figure it's worth a shot for $45.
http://www.autoramps.com/ultra_ramps.htm
http://www.myvirtualpaper.com/doc/ca...1/212.html#212
Old 06-06-2014, 11:50 AM   #5
Cheetoh
You get what you pay for.... If you think $300 is to much for a $40,000 Car, I guess you need to find other options......
Old 06-06-2014, 12:10 PM   #6
BigRed585Lbs
Drives: Sierra and Tahoe
My Rhino ramps work fine for my '14.
And for the "uh oh!" department, the first time I tried backing up them to raise the rear so I could paint the mufflers, I screwed up and backed completely over them! Wham! But the auto gods were smiling and no damage at all was done to the car and there was enough clearance to get the ramps out from under the rockers with out tearing anything up. Glad all my neighbors have to work for a living and there were no witnesses to my stupidity.
That's my tale and I'm sticking to it.
BigRed585Lbs is offline   Reply With Quote
Old 06-06-2014, 12:23 PM   #7
maddoggyusa
good story bigred.
my dumb move was the camaro's 1st oil change. since my ramps didn't work, I used some 2x4's. car was still low but I could make it work. I forgot to pull the plug out of my oil collection pan... and soon had 7 quarts of oil running in my driveway. lol
Old 06-06-2014, 12:29 PM   #8
BigRed585Lbs
Anyone use a Fumoto valve?
Old 06-06-2014, 12:33 PM   #9
fradaj
Drives: RS
I used the jack to raise the front left side. Had enough room to loosen the drain plug. Lowered it in between draining and putting the drain plug back on.
fradaj is offline   Reply With Quote
Old 06-06-2014, 12:57 PM   #10
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
Buy some wood and make your own?
slick rick is offline   Reply With Quote
Old 06-06-2014, 01:35 PM   #11
maddoggyusa
slick rick... those look great. I'd do that if I didn't already have ramps.
I have to make a set of cribbing blocks like below (E38 6-speed conversion)... so I'm trying to keep the clutter minimized.
Old 06-06-2014, 02:40 PM   #12
trashmanssd
trashmanssd's Avatar
Slick rick Nice idea with the little cheater boards on each riser. 2" risers with 1" helper boards in front of them to make it more gradual. Nicely Done. And for me just about free I can find the wood in few our rolloff dumpsters from contractors. 2x10's are not cheap a lot cheaper then 300$ bet that coasted under 50$ all in and the satisfaction of seeing your handy work every time you do your own oil changes.
Old 06-06-2014, 05:24 PM   #13
ActNup NY
ActNup NY's Avatar
Drives: 2011 1LT Black Camaro
I made my ramps out the Home Depot wood as well. I like how your look though . Nice !
The DREAM is free... It's the HUSTLE that is sold seperately
ActNup NY is offline   Reply With Quote
Old 06-06-2014, 05:30 PM   #14
RobertRS
RobertRS's Avatar
Drives: 2014 2SS L99
I thought maybe those boards were faced off with a router.
RobertRS is offline   Reply With Quote
