Old 06-04-2014, 05:15 PM   #1
binko
Drives: Honda Accord
New found leg room.
I have had my seat all the way back in travel and tilt. I noticed that there was still some room behind the seatback and the carpet behind the back rest. There is a way to get the seat to travel further back AND recline further as well.
1. Move the seat to its full forward position.
2. Pull the carpet out that sits behind the back of the seat so that the rear bulkhead is exposed.
3. You will find a black plastic wire channel that routes wires to the rear of the car.
4. On top of that channel you will find a clear flexible strip about 1 1/2" wide that runs from the bottom of the bulkhead to near the top. Unplug the small 2 wire connector near the top of the strip and secure it so that it does not rattle.
5. You will now no longer be limited in seat travel or tilt and can squeeze some valuable additional leg room out. This applies for both seats
I hope this helps you tall guys like me out.
binko is offline
Old 06-06-2014, 08:14 AM   #2
keitht4
1st Corvette-Love it!
keitht4's Avatar
Drives: C7 Z51 2LT
Awesome fine!!!! Made a nice difference for me. Thanks!
keitht4 is offline
Old 06-07-2014, 05:40 AM   #3
emsguy
Drives: 2012 2ss convertible
isn't the rearward seat travel limiter the source of a recall? I thought that the limiter was there so that the seat was prevented from going too far back and chafing the wires.
emsguy is offline
Old 06-07-2014, 07:23 AM   #4
binko
The wires are in a pretty hearty fully enclosed plastic tray. On top of that they also have the carpet over the tray.
I felt comfortable in doing mine. It made a huge difference in comfort for me.
binko is offline
Old 06-07-2014, 08:22 AM   #5
carnut52
carnut52
Drives: Changes often
Me too. I am 6'4'' and the car seemed cramped. I have a ZR1 also and it's much more comfortable to drive. The C7 seat was my biggest disappointment with the car. The seat tip was a great find. I was thinking of getting rid of the C7 because it wasn't fun getting in or out of. I would always pop the trunk release every time I got in the car unless I made a conscience effort to avoid it. So far this change in seat travel has made a big difference to me
carnut52 is offline
Old 06-07-2014, 09:40 AM   #6
Nate GM
Rand Paul 2016
Nate GM's Avatar
Drives: Corvette Stingray Z51 2LT
Great post!! I will definitely try this out on mine.
Nate GM is offline
Old 06-07-2014, 06:14 PM   #7
kevin1106
kevin1106's Avatar
Drives: 2015 ZO6 3LZ Stage 2 A8
Worked like a charm! Great find and post... Should be a sticky!
kevin1106 is offline
Old 06-14-2014, 11:34 AM   #8
khalil0202
Drives: In line for 2015 Z51
I'm 6'-4" and this is great news....... Thanks
khalil0202 is offline
Old 06-14-2014, 03:07 PM   #9
Nate GM
Rand Paul 2016
Nate GM's Avatar
I'm 6' 2" and ended up not even needing to do this. I was very happy and pleasantly surprised with the amount of room. But I'm sure that this will still be helping a lot of Stingray owners.
Nate GM is offline
Old 07-26-2014, 06:41 PM   #10
faninc
Drives: 2010 Camaro RS in SIM
Anyone have a picture of before and after?
faninc is offline
Old 07-28-2014, 09:14 AM   #11
GeoC
Drives: 2014 C7 LT2 Z51 Coupe
I'm 5'18" will use this advice on mine
GeoC is offline
Old 07-29-2014, 12:15 PM   #12
theanswriz42
Drives: BMW E89
Damn, you're tall.
theanswriz42 is offline
