#1 |
![]() Drives: 2014 Cyber Gray Coupe - 2LT Manual Join Date: Mar 2014
Airbag Warning Sticker
Has anybody removed the airbag warning stickers from the visors? I don't want to try to start to remove them to find out they don't really come off.
#2 |
![]() Drives: 1974 & 2014 Corvette Stingrays Join Date: Mar 2013
They aren't really stickers. They're more like an iron-on decal and can't readily be removed without damaging the fabric on the visor. There's several on-line vendors selling black vinyl decals to cover them. That would be your best option. One forum member used carbon-fiber pattern Dynoc which really goes well if you have the carbon dash trim.
#3 | |
#4 |
![]() Drives: 2014 Corvette 2021 Tahoe Z71 Join Date: Jul 2011
Here are some posts from the Corvette Forum on this topic.
http://forums.corvetteforum.com/c7-g...ce-needed.html
#5 |
GAHDOOSH
Drives: 2016 Camaro 1SS Join Date: Apr 2013
Okay... I tried to do this to mine and I ended up having to buy new mirrors. They're $75.00 per visor from Gm. I spent HOURS at a table with a blow dryer and goo-be-gone and it was all for nothing. I would not try doing it again. Just my advice, a lot of people on here seem to do it very easily.
GAHDOOSH
2017 2SS 50th Anniversary Manual, Performance mods: two car seats |
#6 |
![]() Drives: 2010 Lexus, 2014 Z51 C7 on order Join Date: Apr 2014
Sounds like a sticky situation. I would not attempt to take the label off.
#7 | |
![]() Drives: 2014 Corvette Coupe Join Date: Mar 2014
How about this solution?
See my post No. 3 here for material list to make the covering: http://www.corvette7.com/forums/show...43#post7695343 |
#8 | ||
![]() Drives: Cyber Gray Metallic 1LT Coupe Join Date: May 2014
That's what I am doing. Have the parts but no car yet. Thanks for the idea. |
#9 |
![]() Drives: C7 Join Date: Aug 2015
The seatbelt warning stickers are obnoxious on so many levels; "Don't put a child in front seat or they may be killed" - seriously - in a Vette. They are UGLY, government lunacy and repeated in SPANISH?? OK - they are a sticker and can be removed. I used a heat gun and they peal rather easily, hairdryer would probably work. Be careful as it is easy to get a "bubble" w. too much heat. I did, but it came out. After removal you will find a film of glue. I noted in forum a 3M product works - I could not find at several stores. I used Motsenbockers Liftoff found at any Lowes. It does remove the glue and will not harm fabric. I had to apply heavily twice (use a towel to apply, do not spray). Wash the Liftoff away w. soapy water.
