Old 05-23-2014, 05:18 AM   #1
CFD
Drives: 2SS/RS L99 BLACK
diagnostic. help
Here's the issue. Custom built roadster with an ecm from a 2002 vette. Car ran perfect,sat for several months and battery went dead. Jumped it started and ran fine, drove a short distance shut it off. Needed to be jumped again, car now starts, runs for a second or two and dies. Any thoughts?
Old 05-23-2014, 05:27 AM   #2
Mikes fast ss
Slowhawk Built
Mikes fast ss's Avatar
Sounds like the alternator or the battery is shot.
Mikes fast ss is offline   Reply With Quote
Old 05-23-2014, 05:34 AM   #3
CFD
The battery has been replaced and the system is charging. The car starts fine but dies , the injectors run dry ,feels like a theft deterent.
Old 05-23-2014, 05:42 AM   #4
Mikes fast ss
Slowhawk Built
Hmmm, maybe. Once the car is dead for a while it def could be. Beats me.
Gd luck George.
Old 05-23-2014, 05:48 AM   #5
CFD
Gd luck George.
Thanks, if it is an anti-theft issue how would you reset it?
Old 05-23-2014, 06:17 AM   #6
heymatt
heymatt's Avatar
Drives: 2012 IBM 2SS Vert.
Fuel pump issues? Clogged fuel filter?
LS3/M6 K&N, VMAX throttle body, RX Catch Can, skip shift eliminator, DT shorties and Solo HFC, DRL harness and 5K LED DRL, ZL1 rear sway, 1LE front sway
heymatt is offline   Reply With Quote
Old 05-23-2014, 06:33 AM   #7
CFD
Fuel system is new and clean. Fuel pump is working properly
Old 05-23-2014, 12:04 PM   #8
Scalded Dog
Scalded Dog's Avatar
Drives: 2011 1LT
Just happened to see this... by chance, the OP is discussing a similar issue with Corvette. There are a number of suggestions in the thread, some of which haven't been suggested in THIS thread.. maybe you'll find it there?
http://forums.corvetteforum.com/c5-t...-off-help.html
Scalded Dog is offline   Reply With Quote
Old 05-23-2014, 11:13 PM   #9
derklug
derklug's Avatar
Drives: 12 Boss 302
If you have an anti theft problem, you can reset the system by following this procedure.
1. Turn key on and try to start, leave key on for ten minutes or untill the anti-theft light goes out
2. Turn key off for ten seconds.
3. Turn key on but do not start. Leave key on for ten minutes or untill the theft light goes out. Repeat 2 and 3.
4. Turn key off for ten seconds and then try to start the engine.
This will work on most GM vehicles, but I can't guarantee it will work on your set-up. Before starting the relearn process, hook up a battery charger. If the battery goes dead while in relearn, you will have to start over.
The biggest mistakes in life come when you know exactly what you are doing.
derklug is offline   Reply With Quote
Old 05-24-2014, 04:16 AM   #10
CFD
Thanks, I'll have them try it and see what happens.
Old 05-24-2014, 08:42 AM   #11
mickss
mickss's Avatar
Drives: 2010 Camaro LS-M6 67 Chevelle Wgn
If it is the anti-theft system and by your description it seems like it is, you could always eliminate that portion of the system using the following unless you want to keep the anti-theft system;
http://newrockies.com/
I`ve used this system when I did and engine and ECM swap and have not had any issue for almost 2 years. If you do use this system, buy the USA module not the Chinese module, Their probably both good, I just have a problem with trusting inexpensive labor but then again paying top dollar isn`t always a guarantee of quality either.
Good luck, I hope it something simple and inexpensive.
mickss is offline   Reply With Quote
Old 05-30-2014, 08:34 PM   #12
CFD
Figured I'd update this. The ECM used has the antitheft function disabled. The ECM was sent back to the vendor and they think that when the car was jumped it damaged the unit as it tests bad. They are sending a new one to install.
