Go Back   Chevrolet Corvette Stingray C7 Forum > Technical Forums > Cosmetic Maintenance: Wash, Wax, Detail, Bodywork, Protection
Old 05-16-2014, 07:53 PM   #1
mbowen89
Drives: 2015 CRT 2SS/RS 1LE
Car window residue impossible to remove
So... I washed my car and did a quick careful job of drying it off quickly, however I didn't really dry the windows and now there's hundreds of drop sized "residue". I've washed the car again, used Windex, scrubbed hard as I could but it won't come off. I can barely get it off by scratching with my finger nail really hard.
I guess this must be some stuff that was in the water and won't come off after drying.
Is there special window cleaner that can remove this. Again, I can't believe scrubbing hard as I could with a rag wouldn't even remove this...
mbowen89 is offline
Old 05-16-2014, 08:21 PM   #2
purpleRac3r
purpleRac3r's Avatar
Yes, there are. First, try an automotive specific glass cleaner instead of regular Windex. They have special ingredients for cutting grime and dirt not normally found inside a house. I also use only high quality microfiber cloths. If this doesn't work, Mothers, and probably others, have a water spot remover for glass. Its actually a very, very fine polish. Works quite well based on the one use I had for it. But it does require a little elbow grease. Everything should be available at your local auto parts store.
purpleRac3r is offline
Old 05-16-2014, 08:26 PM   #3
mbowen89
I'm guessing it's just minerals or something in my water like lime or iron? The automotive cleaners get all that pretty well?
I just can't believe a lot of elbow grease with my microfiber and Windex doesn't even work at all...
Thanks for the tips I'll check what's available...
mbowen89 is offline
Old 05-16-2014, 09:25 PM   #4
mbowen89
I just bought invisible glass, all they had really, hope this works...
mbowen89 is offline
Old 05-18-2014, 06:21 PM   #5
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
Try CLR on a microfiber towel from the grocery store.......then wash normally, windex, etc...
also vinegar may get it...if you etched it, it's gonna take a orbital/orange foam or MF pad with a mid range polish like Meguires 105 and then finish with 205...
Glen e is offline
Old 05-18-2014, 09:05 PM   #6
mbowen89
The invisible glass with a microfiber actually worked great. I don't know what is in it and not Windex but glad it worked.
mbowen89 is offline
Old 05-19-2014, 06:11 AM   #7
purpleRac3r
As mentioned, the automotive glass cleaners have extra ingredients specific for road grime. Windex doesn't. I don't know what those ingredients actually are tho. I do know I never use Windex on any of my cars anymore! The automotive cleaners also work much better removing the oily film that builds up on the inside too.
