Old 05-07-2014, 05:57 PM   #1
JIM D
Drives: Ordered coupe LT2 artic white
Oil consumption
I have five thousand fun filled miles on my wonderful C7, and when I checked my oil today I was low. Oil pressure was fine. No oil light on. Oil temp normal. I had to add two quarts to get the level up to the area between the hash marks on the dipstick. Got delivery in January and I checked the oil level then and it was fine. Anyone else have this issue? Is it normal to use two quarts in the first 5 thousand miles? Thanks in advance for any advice. Jim D
JIM D is offline
Old 05-07-2014, 06:21 PM   #2
goldbug
Drives: 2014 Stingray
Under the New Vehicle Break-In notes in the manual, page 9-18:
Check engine oil with every refueling and add if necessary. Oil and fuel consumption may be higher than normal during the first 2414 km (1500 mi).
goldbug is offline
Old 05-07-2014, 09:38 PM   #3
JIM D
Goldbug- thanks for the response. When you checked your oil levels, did you find that you needed to add oil and if so how much did you add over your first 5K. Thanks. Jim D.
JIM D is offline
Old 05-07-2014, 09:56 PM   #4
hotwheels65
hotwheels65's Avatar
Drives: 2014 Limerock Green Z51
We have 4300+ miles on our Z51. Most of it [3330 miles] during a round trip from Buffalo to Winter Haven, FL and return. I checked the level at every fill up and it has stayed within a 1/4 inch of where it was the day we picked it up. Enjoy your C7. If you drive it hard you should check the oil at every fill up.
hotwheels65 is offline
Old 05-08-2014, 04:36 AM   #5
Track
Drives: Z51 Corvette Convertible
Jim D - Do you have a Z51? If so, I assume you read the manual and have to warm the motor before checking the oil. If you do not it will show 2 quarts low.
Track is offline
Old 05-08-2014, 05:37 AM   #6
JIM D
Non Z51
JIM D is offline
Old 05-08-2014, 06:44 AM   #7
Searious
Searious's Avatar
Drives: Crystal Red C7 2LT Z51
I just hit the 1500 mark and my level stayed spot on from pickup until now. Z51 for me, so it includes letting the oil warm up, but that consumption sounds a bit high for normal driving. Hopefully some others with a few more miles can chime in.
C7 Status:
1100 - 2/10/14
3000 - 2/12/14
TPW - 3/17/14
Born - 3/20/14
R8C - Pickup on 4/3/14!
Searious is offline
Old 05-08-2014, 08:53 AM   #8
goldbug
I'll let you know, if/when I ever take delivery. (also 5k might take me a good portion of a year to accumulate)
goldbug is offline
Old 05-08-2014, 08:56 AM   #9
JIM D
Goldbug- I know you have heard this before, it's worth the wait. Everything good you have read about the c7 is true. It is a fantastic sports car.
JIM D is offline
Old 05-08-2014, 09:07 AM   #10
route66
Drives: 66 coupe 78 pace car 2014 coupe
Non Z51 took delivery in Sept. only have 3300 miles but oil level has stayed at the same mark since pick up.
route66 is offline
Old 05-08-2014, 11:48 AM   #11
Pete r welch
Same as Rt. 66
Pete r welch is offline
Old 05-25-2014, 04:20 PM   #12
thrilled
Drives: 1LT
Um I don't understand Z-51 same exact engine as the non Z-51 engine so checking the oil should be exactly the same.What am I missing.
thrilled is offline
Old 05-25-2014, 04:25 PM   #13
thrilled
Drives: 1LT
I just answered my own question,the difference is A dry sump pump.
thrilled is offline
Old 05-25-2014, 04:35 PM   #14
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
So you have not checked the oil since jan?
Dangerous habit.......
Glen e is offline
