Old 04-25-2014, 05:40 PM   #1
Corvette7Tuning
Drives: 2014 corvette stingray
NEW AFE COLD AIR INTAKE FOR THE 2014 CORVETTE STINGRAY
Application. This AFE Cold Air Intake System is specifically designed to fit the 2014 V8 Corvettes with the LT1 V8 engine. No tune is required.
aFe is introducing the all new Momentum sealed cold air intake system for the 2014 Chevrolet Corvette (C7) with the V8-6.2L engine. This all new Momentum intake system resulted in 18 horsepower and 22 lbs. x ft. torque and outflows the factory intake by 42%. This system is superior in every way, from the one-piece sealed housing, to the massive air filter, roto-molded tube w/ built-in resonance chamber and premium hardware. This system uses a CAD designed, dyno-tuned, roto-molded intake tube & housing to achieve maximum power gains while maintaining a perfect fit. This is a direct bolt-on kit and requires no cutting or drilling on OEM parts.
Unique One-Piece Housing w/ Sight Window:
The one-piece sealed housing is used to eliminate the use of multiple components and ensure the coolest air intake charge available. A large clear sight window allows for filter inspection without removal of the air box. The roto-molded housing is made out of black cross-linked polyethylene and mounts directly into the factory location on the fender well to capture the coolest air available from the factory intake tract.
Roto-molded Tube:
This system uses a CAD designed, dyno-tuned, roto-molded intake tube to achieve maximum power gains while maintaining a perfect fit. This tube has a built-in resonance chamber to catch un-wanted air intake noises. Two billet aluminum fittings are mounted on the tube to provide a perfect connection with the factory vacuum lines.
Massive Cone Air Filter:
This Momentum intake system was designed around the largest filter possible to allow maximum performance and filtration. This cone filter has a massive 7" oval flange and is 9-1/2" tall Pro 5R filter media. The Pro 5R performance air filter features 5-layers of progressively finer mesh cotton gauze oiled media and is constructed with 100% polyurethane frame for long life and multiple cleaning cycles.
Premium Hardware:
Premium stainless steel T-bolt clamps and a reinforced silicone hump coupler are used for strength and durability while also providing the most secure installation available. Momentum intakes are designed with fewer parts for a quick and simple installation.
Proven Results:
After a rigorous design and testing phase, the results are in. The Momentum air intake system outflowed the factory intake by 42% and resulted in 18 additional horsepower and 22 lbs. x ft. torque.
http://www.corvette7tuning.com/afe-c...stingray-.html
2014 Corvette Stingray Parts & Accessories
Lowest Prices & Free Shipping!
www.Corvette7Tuning.com
Corvette7Tuning is offline
Old 04-25-2014, 06:15 PM   #2
m3incorp
Drives: Buying 2014 Stingray
Sounds good. Price?
m3incorp is offline
Old 04-25-2014, 06:30 PM   #3
Corvette7Tuning
On sale for $495
Old 04-25-2014, 08:15 PM   #4
1KUIKC7
1KUIKC7's Avatar
Drives: 2015 Zo6 3zl
I like it!
Glen F.
1KUIKC7 is offline
Old 04-25-2014, 09:58 PM   #5
Stingray
just can't get enough
Stingray's Avatar
+18hp and +22tq without a tune... wow what an increase!
Stingray is offline
Old 04-26-2014, 04:14 PM   #6
1KUIKC7
1KUIKC7's Avatar
Maybe my second mod!
Glen F.
1KUIKC7 is offline
Old 04-26-2014, 06:04 PM   #7
Ret9580
Drives: '99 Sienna till '15 Ray is here
Originally Posted by Corvette7Tuning View Post
On sale for $495
Would this affect the warranty??
Ret9580 is offline
Old 04-26-2014, 09:29 PM   #8
chazysoccer11
chazysoccer11's Avatar
Drives: 2011 Chevrolet Camaro SS/RS
This would not affect your warranty.
2011 2SS/RS RJT M6.
PCTXHN Ordered 8/4/2010 Built 9/28/2010
chazysoccer11 is offline
Old 04-27-2014, 12:11 AM   #9
1KUIKC7
1KUIKC7's Avatar
Even so you can always throw the original back on.
Glen F.
1KUIKC7 is offline
Old 04-27-2014, 09:39 AM   #10
mowilson329
mowilson329's Avatar
Drives: 2014 Stingray 1LT/Z51
Sounds like a great price. Does anyone know how difficult the installation is? If you had to rank it on a scale of 1-10.......1 being easy all the way through 10 being very difficult (professional recommendation).
Cliff
mowilson329 is offline
Old 04-27-2014, 10:20 AM   #11
1KUIKC7
1KUIKC7's Avatar
I have done them on my C6's maybe a 4, very simple.
Glen F.
1KUIKC7 is offline
Old 04-27-2014, 03:07 PM   #12
chazysoccer11
Installing a cold air intake is a matter of reading directions and have a few simple tools. I am no mechanic, but I installed a new cam, pushrods, and springs, etc. in my LS3 all by myself. You can do anything as long as you can read and follow directions.
A cold air intake would be a 2 on level of easiness. You got this.
2014 corvette cold air intake
